  New Posts New Posts RSS Feed - scoop compatible drivers...
 Post Reply Post Reply Page  <1234 17>
Post Options Post Options   Thanks (0) Thanks(0)   Quote jbl_man Quote  Post ReplyReply Direct Link To This Post Posted: 26 April 2012 at 8:49am
Just out of interest,has anyone ever put an Eminence driver successfully in a scoop?
Ditto what Lev says about the cerwins,most in that list are very old,the 189 must be 25+years old now,3 inch coil,paper cone,and only 400w...probually fine for a vintage sound,but you wouldnt want to use it in anger.
levyte357 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357 Quote  Post ReplyReply Direct Link To This Post Posted: 26 April 2012 at 10:42am
EDITED
Edited by levyte357 - 11 May 2012 at 1:32am
UpComingSound View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote UpComingSound Quote  Post ReplyReply Direct Link To This Post Posted: 27 April 2012 at 6:06pm
any one know about then new B&C drivers
18 TBW100 - 18" EXTREME HIGH POWER WOOFER
  • THE NEW B&C 18 TBW100 IS A VERY HIGH POWER 18" WOOFER THAT HANDLES 1,500 WATTS AES STANDARD & 3,000 WATTS PROGRAM
  • EXTENDED XMAX OF 12.0MM FOR A VERY DEEP TIGHT CHEST POUNDING BASS SOUND
  • ALUMINUM DEMODULATION RING KEEPS FLAT RESPONSE & DISTORTION LOW
  • CONE IS WATERPROOF ON BOTH SIDES
  • FEATURES A DOUBLE SPIDER, VENTILATED VOICE COIL GAP & A LARGE 4" VOICE COIL
  • THE B&C 18 TBW100 SPEAKER IS OPTIMIZED FOR EXTREMELY HIGH OUTPUT SUBWOOFER SYSTEMS IN CONCERT, SOUND REINFORCEMENT SYSTEMS, THEATER, ETC.
  • SEE SPEAKER CABINET SPECIFICATIONS AT BOTTOM OF PAGE FOR BUILDING YOUR OWN CABINET
INTENSE STRONG BASS W/ HIGH POWER HANDLING OF 1,500 WATTS AES W/ A VERY HIGH XMAX OF12.0MM!
B&amp;C 18TBW100B&amp;C 18TBW100
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357 Quote  Post ReplyReply Direct Link To This Post Posted: 27 April 2012 at 6:13pm
EDITED
Edited by levyte357 - 11 May 2012 at 1:33am
Dub Specialist View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dub Specialist Quote  Post ReplyReply Direct Link To This Post Posted: 27 April 2012 at 6:41pm
nothing wrong with Emimence drivers in scoops sigma n omega thay work well. I sometimes still use them .still got well old pair a scoops with emmys
horses fi courses if you ent tearing down the walls of babylon.there allright..LOL..come on man i memba using 400w drivers n still rumbling places..sometimes we haffi tek a step back...still respects to all...
its not allways bout power power power...
Edited by Dub Specialist - 27 April 2012 at 6:54pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357 Quote  Post ReplyReply Direct Link To This Post Posted: 27 April 2012 at 7:04pm
EDITED
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dub Specialist Quote  Post ReplyReply Direct Link To This Post Posted: 27 April 2012 at 7:31pm
Go into Golden Palace,  with Eminence loaded scoops, up against other sounds, and watch what happens... LOL
http://image.shutterstock.com/display_pic_with_logo/101102/101102,1222340956,1/stock-photo-big-male-lion-eating-an-animal-carcass-17908138.jpg
These days, 4x scoops can do what 8x used to do, because people have progressed to higher power drivers, and larger amps.
true true i dont disagree lev but like i said thats not horses fi courses there is a place for every speaker/amp in this world man .. mi bredrin got some 300w cabs system ect ect f--k no watt thay am n
now he earns bear moneys man..dont get mi wrong man we do it fi the love man .. ..he dont need pd fane 1500 celstion ect ect ..sometimes we wraped up inna the big sound dem an earn f---k all ..respeck evertytime mi bredren..
Andy Kos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andy Kos Quote  Post ReplyReply Direct Link To This Post Posted: 27 April 2012 at 11:52pm
Kilomax is too fussy, and often disappoints. .
But dont forget the Kilomax does have an enormous heatsink on the front, and before it starts sucking all your amp power into that heatsink the first 400-500W of the 1250W it rated at can actually be turned into sound instead of heat!!!
Ras Loud View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ras Loud Quote  Post ReplyReply Direct Link To This Post Posted: 28 April 2012 at 12:34am
Now I know what that is. I thought that thing was just there to protect the cone.
RealitySound View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RealitySound Quote  Post ReplyReply Direct Link To This Post Posted: 28 April 2012 at 2:09am
Originally wasn't the whole reasoning behind building big horn type boxes to get maximum sound out of crap low output drivers?
Edited by RealitySound - 14 June 2012 at 11:30pm
Enough with the bass jokes, Just drop it.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andy Kos Quote  Post ReplyReply Direct Link To This Post Posted: 28 April 2012 at 2:15am
Originally posted by RealitySound RealitySound wrote:
Originally wasn't the whole reasoning behind building big horn type boxes to get maximum sound out of crap low output drivers? There wasn't any servodrives or bassmaxx trips at Woodstock. Probably primative 100 watt woofers in fridge size horns.
I think two lists of scoop compatible drivers should be made.....The first being standard everyday affordable drivers that have parameters that actually make them to be able to use in a scoop. Simple, everyday working class people drivers- for when you find a couple pieces of sh1t plywood,....and decide,....I think I'll build a scoop for my little house parties or man-cave/basement, or whatever, and wonder what cheap piece of crap driver can I get down the street for my scoop without the wife noticing that were short for rent this month. Not really intending on rattling the fillings out of my neighbors teeth, or soundclashing every tinpan with scoops, just a little boom boom, rumble rumble at a decent sound pressure level when the wife goes out of town with the kids and you feel like dusting off your August Pablo album. No true?
The second list being Lev approved Thumbs Up super dooper awesome (and probably expensive) drivers, for when you really really truly must have the ultimate performance out of your cab. Which is not a bad thing at all, if that is your intention.
man-cave/basement - think I'll start work on building myself a man-cave... Im sure thats what is missing in my life
Post Options Post Options   Thanks (0) Thanks(0)   Quote RealitySound Quote  Post ReplyReply Direct Link To This Post Posted: 28 April 2012 at 2:32am
Totally. Every man should have one.
