  New Posts New Posts RSS Feed - scoop compatible drivers...
 Post Reply Post Reply Page  <12345 9>
RealitySound View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RealitySound Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2012 at 10:02pm
Void drivers in the UK cost approx 192-220 pounds ( 310-350$US) 4 shipped to me costs approx $700. Add it all up and they cost $525 each when I get them.
Its 200$ more to ship 4 drivers from the UK than the US. So to all the americans on here- If you were to order 4 direct from void (192 pounds)(310ish USD) by the time it reaches New Jersey They will be about $450 USD each.
We learn something every day, and lots of times it’s that what we learned the day before was wrong.
levyte357 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357 Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2012 at 11:54pm
EDITED
Edited by levyte357 - 11 May 2012 at 1:31am
Post Options Post Options   Thanks (0) Thanks(0)   Quote RealitySound Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2012 at 12:18am
Thanks Lev, but I honestly don't think I'll ever pay over $600 for a driver. Void looks good to me, and so similar to PD already.
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357 Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2012 at 12:26am
EDITED
Post Options Post Options   Thanks (0) Thanks(0)   Quote RealitySound Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2012 at 12:48am
Here's quick way to choose decent "ferrite" scoop driver for scoop.
Ignore manufacturer's sensitivity figure, only consider reference efficiency, expressed as figure between 1.8 - 4.0.
Forget all Eminence, Paudio, Cerwin Vega, Peavey drivers
Forget all drivers where Xmax < 7mm
Forget all drivers with VC diam < 4"
Forget all drivers where ref efficiency (no) < 1.8
Forget all drivers with BL < 24 (Except PD186), or  Qes > 0.35, or Qts > 0.35, or Vas > 360, or Fs > 35hz
Separate drivers into 2x groups,
BL, qts, Vas,  similar to PD1850, or similar to Void V18-1200.
                           VOID   PD1850 PV-LOWMAX B&C.TBX100 FP18HP1020 FP18XL1600 FANE.COL-1500
XMAX  7mm+       10.5     11.25         8.25           9                  9.5             13                    12.75
 BL       24+          34.8      31              25           25.5              27.2            28.1                  32.74
QES    .35-             .22      .22             .33           .37               .29              .37                    .26
QTS    .35-             .22      .21             .32           .35               .28              .36                    .25
VAS   360-             201      249            295          212              219             195.5                 175
FS    35hz-              34        30            33.5          34                35                32                    33.5
FP is Faital Pro.
Forget all Peavey drivers but the lowmax.
Thumbs Up
Post Options Post Options   Thanks (0) Thanks(0)   Quote RealitySound Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2012 at 2:27am
edited
Edited by RealitySound - 11 May 2012 at 2:11am
t.geessounds View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote t.geessounds Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2012 at 3:29am
how no 18sound in the mix
Post Options Post Options   Thanks (0) Thanks(0)   Quote RealitySound Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2012 at 12:51pm
No worries Jason, never said the list was finished. Probably add em tonight. Thumbs Up
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357 Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2012 at 1:01pm
EDITED
Edited by levyte357 - 11 May 2012 at 1:32am
Post Options Post Options   Thanks (0) Thanks(0)   Quote RealitySound Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2012 at 1:52pm
Noted.
catman int View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote catman int Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2012 at 2:41pm
Since when eminence kilomax became a scoop driver?
Dub Specialist View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dub Specialist Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2012 at 2:51pm
it never was ?? my mate has a pair tho in scoops but i havent heard them he dont want me to here them ..Confused
and also i seen many a soundsystem got/had emmys kilo in scoops , maybe you can get away with it by have a large chamber scoop??? who knows??
Edited by Dub Specialist - 10 May 2012 at 2:53pm
web department
