scoop compatible drivers... |
Page <1 45678 9> |
| Author | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
ILuvDub
Joined: 09 November 2006 Status: Offline Points: 85 |
Posted: 12 May 2012 at 4:44pm |
RealitySound
Joined: 01 February 2011 Location: Bermuda Status: Offline Points: 547 |
Posted: 12 May 2012 at 5:04pm |
Brush it off Lev!
Edited by RealitySound - 04 August 2012 at 3:01am |
We learn something every day, and lots of times it’s that what we learned the day before was wrong.
shockwavesoundz
Joined: 15 May 2012 Location: Barbados Status: Offline Points: 20 |
Posted: 15 May 2012 at 10:06pm |
Im located in Barbados and down here we don't have access to alot of the stuff that i see being mentioned on this site....we have speaker brands such as eminence, peavey, jbl and selenium. I think that basically named all that we get here....in a case like that what road should i take regarding good subs....i currently own 8 scoops loaded with eminence omega pros.....im not familiar with specs and stuff relating to the speaker/ box parameters but most people i know with some good sound systems down here just build boxes and load up.....any input would be appreciated.
RealitySound
Posted: 16 May 2012 at 1:29am |
Link goldentouch. He's a member on here and he is a woofer dealer outta Florida. I'm sure he can hook you up a deal on some decent drivers. 18 sound and such.
shockwavesoundz
Posted: 16 May 2012 at 6:49am |
ok thanks...i'll link him.
RealitySound
Posted: 17 May 2012 at 12:43am |
Surely there must be some more drivers to add....anyone?
RealitySound
Posted: 02 June 2012 at 1:55am |
SCOOP COMPATIBLE OR NOT?
LIST SO FAR....... XMAX(7+)/ BL(24+)/ QES(-.35)/ QTS (-.35)/ VAS(-360)/FS(-35)/ RMS/GBP/USD (18sound) 18W1000 7 24.7 .24 .23 268 35 1000W $300 18LW1250 9 23.6 .28 .27 268 35 1000W ? 18LW1400 9 24.7 .31 .29 297 31 1000W $360 18LW2400 9.5 25.6 .32 .31 230 35 1200W $330 18W2000 7 27.1 .26 .25 230 37 1200W 240E 18NLW9000 14 27 .32 .31 206 34 1800W 380P 18NLW9600 14 30 .29 .28 149 34 1800W $700 18ND9300 9.5 24.4 .29 .28 316 30 1000W $500 18NLW9400 9.5 26 .28 .26 268 33 1200W B&C TBX-46 9 25.8 .33 .31 227 34 1000Wdiscontinued B&C TBX100 9 25.5 .37 .35 212 34 1200W $316 B&C18PZB100 8 26 .25 .24 297 30 700W $315 B&C18NW100 9 28 .27 .26 252 31 1200W $400+ B&C18SW115 14 30.3 .32 .3 187 32 1700W $582 Beyma18G50 9 28.8 .334 .325 212 40 750W $380 Beyma18G550 9 24.4 .385 .37 210 36 900W $390 Beyma18P1000 8 26 .37 .36 245 32 1000W $460 Beyma18p1200ND 9.5 26.3 .35 .34 198 37 1200W $630 Beyma18SW1600Nd 10 29 .34 .33 205 32 1600W $700 BMS18S430v2 8 23.5 .36 .34 262 31 1200W 304E BMS18N850v2 13 26.2 .36 .34 247 29.7 1200W 405Q CelestionCF18VJD 9 30.54 .315 .305 164 33 1600W 330Q/$535 CelestionFTR184080 6 22.88 .29 .27 395 26 1000W $250 Em Definimax4018 7.9 27 .36 .35 238 32 800W $305 Em Impero18C 8.13 16.1 .35 .34 317 31.5 1200W $300 Em OmegaproA&C 4.8 18.8 .32 .31 548 25 800W $200 Em Sigma 6.1 22.1 .3 .29 441 28 650W $170 EV-EVX180B 6.4 22.5 .29 .27 416 29 600W $535 FaitalPro18xl1600 13 28.1 .37 .36 195.5 32 1600W $600 FP18HP1020 9.5 28 .28 .27 207 35 1000W $400 FP18HP1040 9.5 24.5 .35 .34 196 38 1000W $400 FP18HP1060 12.45 24.8 .38 .37 175 35 1200W $450 FANEcol-1500 12.75 32.75 .26 .25 175 33.5 1500W365Q/$590 FANEcolPrimeXS 12 22.4 .404 .385 257 33 1200W $370 FaneCol18B 4 29.5 .207 .197 320 30.5 400W ? FaneCol18B600 7.2 25.25 .245 .236 354 29 600W FaneCol18B800 7.2 25.25 .245 .236 354 32 800W FANEcol18SB 8.25 24 .366 .346 199 36 1000W $290 FANEcol18XB 7.5 25.9 .358 .337 236 33 1000W Q197$300 JBL 2242 9 23.7 .29 .29 283 35 800W $700 P-AudioSD18-1700N 7.5 33.7 .39 .38 88.6 44 1700W P AudioSD18 5 35.8 .27 .26 264 33 800W PD1850 11.25 31 .22 .21 249 30 800W Q335 PD1851 12 31 .3 .29 182 34 1000W Q359 PD186 9 22.94 .326 .312 353 27 700W Q193 PeaveyLOWMAX 8.25 25 .33 .32 295 33.5 1200W $368 PeaveyLowRider 9.6 22.17 .356 .342 288 28.9 800W $205 Radian2218NEO 21.3 29.85 .283 .257 329.4 31.4 1300W $800 RCF,LF18G400 9 24.2 .29 .27 360 28 1000W $435 RCF LF18X451 13.5 30.5 .29 .28 220 30 1800W $500 RCF LF18N451 8.8 30.2 .25 .24 245 31 1500W RCF,LF18X400 9 24.2 .29 .27 360 28 1000W $500 RCF,L18p200-N 9.8 23.1 .32 .31 380 28 800W $365 RCF,L18P300 7.8 23.5 .34 .33 226 33 1000W $390 RCF,LF18P400 9 24.2 .29 .27 360 28 1000W $370 RCF LF18N401 8.8 27.8 .27 .26 257 32 1200W $410 TC.SoundsLmsUltra5400 38.1 26.8 .34 .33 240.7 20.5 2000W TC PRO 5100 31 .25 .25 251 26.5 1000W $1290 Turbomax 1500M3 12.75 35.39 .218 .208 184.95 28.59 1500W Q320 Turbomax 1800 14.1 34.03 .201 .1944 233.57 25.43 1800W Q300 TurbomaxB1000 12.5 24.56 .3951 .3694 238.44 30.7 1000W Q227 VOID 10.5 34.8 .22 .22 201 34 1000W Q235 Wembly B Line 10 24.17 .26 .24 412 25 800W Driver names in Blue tried & tested, Green are good, Red shows where the parameters have fallen outside the general requirements a bit,..but driver will still work fine, just not as great as the others (green) for max spl. Everyone is entitled to their own opinions on how certain drivers sound in certain scoops,...so to each their own, horses for courses etc. Purple is 'close enough' I will add to the list as time allows. Anyone with knowledge on particular drivers, or personal experience with a specific drivers performance in a particular scoop- pass it on.
If there are any drivers that should be on here, let me know. This is a GUIDE. Nothing engraved in stone.Edited by RealitySound - 06 February 2013 at 1:31am |
RealitySound
Posted: 14 July 2012 at 3:36pm |
Added some more Fane & RCF drivers.
DJ Maestro
Joined: 11 September 2012 Location: Surname Status: Offline Points: 44 |
Posted: 11 September 2012 at 7:18am |
Hi there,
Can i use peavey low rider in scoop or folded horn cabs.. these are the specs:
Edited by DJ Maestro - 11 September 2012 at 7:53am |
RealitySound
Posted: 11 September 2012 at 3:29pm |
The BL is a little low for high power tight throat conditions.
Edited by RealitySound - 17 October 2012 at 1:21am |
DJ Maestro
Posted: 11 September 2012 at 6:00pm |
@Reality thanx for replying so fast, keep up the good work man.
can i use this one? Eros E-818 800w rms 8ohm sds (this is brasilian made)
Edited by DJ Maestro - 11 September 2012 at 6:18pm |
DJ Maestro
Posted: 11 September 2012 at 6:07pm |
The country where i living, we have more speakers from china, brands like CBU and SANDY...or Zebra, Eros, selenium and peavey, soundbarrier etc.. i want make 4 horn loaded/scoop cab but really don't know what driver to chose...all information is welcome.....
Thanx |
Page <1 45678 9> |
Tweet
