  New Posts New Posts RSS Feed - Scoop Issue (Plays deep but doesn't hit hard)
 Post Reply Post Reply Page  123 6>
MINTEVENTRESOURCES View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MINTEVENTRESOURCES Quote  Post ReplyReply Direct Link To This Post Topic: Scoop Issue (Plays deep but doesn't hit hard)
    Posted: 12 April 2017 at 1:57am
Hello All,
I have a medium chamber scoop loaded with Eighteen Sound LW1400s. The issue is boxes play deep and full although, they do not have a lot of pressure or hit you in the chest hard. Would anyone be able to lend some knowledge as to what is being done wrong whether design or speaker?
mini-mad View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mini-mad Quote  Post ReplyReply Direct Link To This Post Posted: 12 April 2017 at 4:42am
Yes.... its a sub cab not a bass cab.
Your scoop plays 80hz and dowm. Kick is about 70-200hz.
You want it to THUMP, then build a short horn that plays 70-200hz.
Job done!!
Edited by mini-mad - 12 April 2017 at 4:43am
JR.junior View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JR.junior Quote  Post ReplyReply Direct Link To This Post Posted: 12 April 2017 at 7:12am
Try to reduce throat/chamber size, could be too big for T/S of the driver.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MINTEVENTRESOURCES Quote  Post ReplyReply Direct Link To This Post Posted: 12 April 2017 at 1:48pm
Reducing the chamber size would be the reducing the airspace between the front baffle and the baffle behind the speaker? Would you suggest adding another baffle behind the front? It would not be possible for me to add to the rear baffle as the speaker needs the depth to fit. I could also add wadding?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dub Specialist Sound Quote  Post ReplyReply Direct Link To This Post Posted: 12 April 2017 at 3:12pm
100% chamber size and throat size
there the problem, lack of spl and pressure
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dub Specialist Sound Quote  Post ReplyReply Direct Link To This Post Posted: 12 April 2017 at 3:14pm
Yes you can add a 2nd baffle if that all you got to play with ie without heavy modding and wrekking the box ect
ive dun it plenty times,
you can put on in in 2 pieces fit super flush get the cuts spot on
, glued and screwwed no problem,
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dub Specialist Sound Quote  Post ReplyReply Direct Link To This Post Posted: 12 April 2017 at 3:17pm
So whats the size is the magnet of yu driver from the rear baffle
as i said yu can add it on the rear baffle, thats if you have room of course
Post Options Post Options   Thanks (0) Thanks(0)   Quote MINTEVENTRESOURCES Quote  Post ReplyReply Direct Link To This Post Posted: 12 April 2017 at 3:57pm
Unfortunately, I do not have the exact dimension of how much space is between the magnet and the second baffle. I do not think there is enough space to add to the baffle on the back side. I would have to add it on the inner side of the front baffle. The inner dimensions of the chamber is roughly 24" by 24" by 8.9" if that helps. Now when you say throat issue can that be fixed?
bee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bee Quote  Post ReplyReply Direct Link To This Post Posted: 12 April 2017 at 6:19pm
the lw1400 is a nice driver but not my first choice even for a cheaper end of the range driver.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MINTEVENTRESOURCES Quote  Post ReplyReply Direct Link To This Post Posted: 12 April 2017 at 6:36pm
We all know that the PD, Void, and Turbomax are the most respected and best. With that said those are diffidukt to obtain here in America. What would be you choice for a speaker in this class?
BASSHORSE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BASSHORSE Quote  Post ReplyReply Direct Link To This Post Posted: 12 April 2017 at 7:18pm
what design scoop is it? sound like my super scoops build with a pertrackter,.nuff low end but the other notes wasnt so loud,.i know the ass s118 as got nuff punch too um so you can get anice bass & throw from certain scoops,,but dubs knows is scoops so i would defo say the chamber too big henace the deep bass & no control & punch..
Edited by BASSHORSE - 12 April 2017 at 7:19pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote MINTEVENTRESOURCES Quote  Post ReplyReply Direct Link To This Post Posted: 12 April 2017 at 8:05pm
I do not have the full design either. The cabinet designer / building wasn't a nice guy hence my issue. You are correct. This design is similar to a super scoop without the dogleg, and braces behind the second and third baffle, as well as no brace in the mouth. I do have the 45 degree braces on the rear panel and behind the second baffle. Dub would you happen to have any pictures of the modifications you have done to the first baffle?
