  New Posts New Posts RSS Feed - Scoop Issue (Plays deep but doesn't hit hard)
 Post Reply Post Reply Page  <1 456
flinnt45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote flinnt45 Quote  Post ReplyReply Direct Link To This Post Posted: 21 April 2017 at 9:24am
Hi Mint
Driver with a big vas is required, good low resonance , reasonable qts
RCF l8x400 might suit, you could experiment with the baffle behind the driver, superimpose another on to it, slightly loose around its perimeter so that you can move it, couple of mm should do and move it down by degree,s to reduce the throat size, reduce to 150mm then 125 mm etc this should affect the spl in the desired manner
JAH Kreator Hi Fi
MINTEVENTRESOURCES View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MINTEVENTRESOURCES Quote  Post ReplyReply Direct Link To This Post Posted: 21 April 2017 at 12:48pm
Originally posted by flinnt45 flinnt45 wrote:
Hi Mint
Hello Flinnt45,
Thanks! To confirm the driver you are referring to is the RCF LF18X400? Next adding the baffle behind the first baffle is understood. At the point of moving the baffle down a degree is where you lost me. Are we still discussing the first baffle or now speaking about the second baffle? Please advise, thanks.
Mint Event Resources
