  New Posts New Posts RSS Feed - Scoop Porn
Scoop Porn
 Post Reply Post Reply Page  <1 167168169
DMorison View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMorison Quote  Post ReplyReply Direct Link To This Post Posted: 11 April 2016 at 1:00pm
Originally posted by eyeT eyeT wrote:
<blockquote class="imgur-embed-pub" lang="en" data-id="OYTsthZ"><a href="//imgur.com/OYTsthZ">View post on imgur.com</a></blockquote><script async src="//s.imgur.com/min/embed.js" charset="utf-8"></script> Did that work?
Not Quite.
The best way is to get the actual image url from your host (http://i.imgur.com/OYTsthZ.jpg in this case) and put it inside image tags when you put in in the post here.
Image tags work like this, only without the spaces inside each set of square brackets: [ img ]
Some image sites will do this for you, look for a link that says something like "forum code" or similar then all you need to do is copy and paste.
HTH,
David.
eyeT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote eyeT Quote  Post ReplyReply Direct Link To This Post Posted: 11 April 2016 at 8:03pm
Why thank you, not much of a computerist but I like building boxes
(I do hope I got that right this time)
