  New Posts New Posts RSS Feed - scoop rebuilding
scoop rebuilding
_Natty_ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote _Natty_ Quote  Post ReplyReply Direct Link To This Post Topic: scoop rebuilding
    Posted: 03 April 2007 at 1:30pm
Hi
my first post...so sorry for my english....
We are the owners of some olds scoops, we are thinking about rebuilding them with some B&C 18063n-4 ( is a mix of the 18pzb100 and the 18nw100) with a new comception of magnet made by Neodimio.
At this time the boxes ( as well as the original ones ) mount some speakers with 400\500 wrms... It's a project  from '80s era...I'm looking for some tips about the power, because the new speakers have a power about 900 wrms ( that are almost the double of power), and meybe I can find some problems with the compression into the box, resulting in a loss of performance in the system...
At this time I have some problem for testing the speaker into the box before buying it...
so what do you think about?
If do you need some other technical specifications let me know....
Lapo
italy
Static Age View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Static Age Quote  Post ReplyReply Direct Link To This Post Posted: 03 April 2007 at 2:31pm
the boxes should be ok as long as there have been built with all the braces in the correct places.
however if the boxes already rattle a bit with the current lower power drivers you may have to add some extra bracing/ screws & glue to get them up to spec.
aperrado View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote aperrado Quote  Post ReplyReply Direct Link To This Post Posted: 24 February 2008 at 12:45am
lol im confused   how many kind of scoop we have in the forum
super scoop
mini scoop
hog scoop
are they all diferent on measures wich one is small  i think the super scoop is bigger
Im hard to learn but still asking
mykey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mykey Quote  Post ReplyReply Direct Link To This Post Posted: 24 February 2008 at 3:47am
super scoop
mini scoop
hog scoop
and DubSub
This page was generated in 0.077 seconds.
