Second hand prices on F1 res4?! |
Aztor
Joined: 22 September 2010 Location: Norway Status: Offline Points: 246 |
Topic: Second hand prices on F1 res4?!Posted: 22 February 2012 at 10:28pm |
Hello What's normaly the price for 2x used Res4? And how does it compare VS Turbosound Aspect TA-500DP? http://www.turbosound.com/docs/products/TA-500tDP.shtml I can get a pair for about 5100 £ |
dylan-penguinmedia
Joined: 14 April 2011 Location: Brighton Status: Offline Points: 766 |
Posted: 22 February 2012 at 11:26pm |
Well the Aspect is an active cab, for a start...
penguinmediasolutions.com
duck1
Joined: 22 February 2008 Status: Offline Points: 125 |
Posted: 23 February 2012 at 12:01am |
...and the TA 500 is more of a full range cab. From spec sheet: 60Hz - 20kHz ±4dB (with DSP)
a res 2 is probably a better comparison. Either way, you're probably looking at anywhere from £3.5k up for a fully boxed pair depending on model and condition...
Aztor
Posted: 23 February 2012 at 12:12am |
Thanks. I have FFA 6004 to use with. I know the TA 500 is more a full range cab, was just thinking soundwise on mid-top part. And was thinking the Res 4 touring. Edited by Aztor - 23 February 2012 at 12:15am |
4D
Joined: 13 November 2008 Location: Winchester Status: Offline Points: 2116 |
Posted: 23 February 2012 at 12:34am |
Touring boxes + wheelboards run from 2k to 3k + per box depending on vintage & upgrade status. |
.... The bass was intense. Girls were literally running up to stand next to the subs
csg
Joined: 17 September 2007 Location: bedford Status: Offline Points: 3530 |
Posted: 23 February 2012 at 6:29am |
the TA500 is significantly louder than the res-2 and the res-4, but is slightly weaker in the low mid area. Very different sound, the turbo is quite a dry and clean sounding box, i find res-4's warmer but less extended / transparent in the upper regions.
www.impulseaudio.co.uk
Tweet
