series II P-Audio SN-12MB in X12 |
Post Reply | Page 12> |
jerronimo
Registered User Joined: 11 July 2009 Location: Nederland Status: Offline Points: 438 |
Posted: 28 May 2010 at 3:56pm |
I'm finally going to construct a pair of X12's, and I'm planning to use the SN-12MB's Rog suggested in his original design.
The series I drivers are no longer made, they are replaced with the series IIhttp://www.paudio.ro/pdf/products/SN-12MB.pdf which have a much higher AES value of 600 watts, high value for money as I can get them for around 140,- euro a piece.
I don't have the T/S parameters of the old series I, so don't know if these can be replaced without making modifications to dimension of the cabinet.
Anybody can help in this situation?
Mircea Bartic
Old Croc Joined: 18 February 2005 Location: Romania Status: Offline Points: 2581 |
THey should work well in the X12
the power is not AES it's RMS |
smithshorn
Registered User Joined: 08 February 2007 Status: Offline Points: 253 |
From the info I have the "original" SN12B had a qts of .16, a VAS of 68 and an FS of 48.4
jerronimo
Do you mean the original SN12MB or SN12B mr. Smith?
Because they are not the same.
If I compare those T/S with the T/S parameters of the new one they are very different, the new type will not go below 100 hz very efficiently I think?
I have to cut my subs at about 80 to 100 hz, so there will be not much room to play with.
smithshorn
My mistake. I thought I had the "old" PDF in my files. I'll have to look again.
Tony Wilkes
I have the old PDF for the SN12MB, If you want to send me a PM with your Email address I will send it to you.
Tony |
lee500
New Member Joined: 18 October 2010 Status: Offline Points: 1 |
Thanks for sharing this post.This site is very helpful for me and others
MarjanM
I have two of those new SNII series. Will test them next week.
cravings
well marjan, did you test them? i'm reading a lot about 12" drivers for X12 type boxes these days..
MarjanM
To be honest i didnt had a time to do it. Today i am cutting some plywood for the new Bold Audio BA12 model and i will try to do spare baffles.
Problem is that they dont fit in any of my boxes. They need few mm bigger hole. What i can tell is that they are super light, they are nicely build, but from what i can see they have very stiff suspensions and i dont think they will go very low. Not sure that they can be used in a full range box. I expect great results 80Hz and above. Maybe they need to run in a bit. Dunno. This few days will tell.
cravings
i'm just running ideas round my head at the moment.. no concrete plans. but in the next couple of months i may put something together for something: a pair of g-subs with fane xbs, and a pair of X12 type tops, with p-audio horns and comps (which i already have), and i'm thinking over the 12" drivers.
weight wouldn't be an issue at all, so if things are more expensive just because they're light, i'd go for the heavy... with that in mind.. currently thinking about the BMS 12S320.. cheers anyway. |
MarjanM
You cant go wrong with bms. Comparing the build quality between paudio and bms, paudio dont stand a chance at all. I have a lot of bms drivers now having take over the complete Bold Audio production and no real comparison to be honest. Only advantage on the paudio side is the price. Not sure what the price is there, i got them for 85 us$ each.
