series/parallel |
Post Reply | Page 12> |
crystal.a
Registered User Joined: 25 June 2009 Location: w.sussex Status: Offline Points: 184 |
Posted: 05 September 2012 at 10:29pm |
is there any way using a combination of series/parallel wiring i can run 3 bins a channel without it being a 2.66 ohm load??
hell is just a word, the reality is much much worse!
djeddie
If you have 2 bins in series that are then paralleled with 1 bin, you have a load of 5.33Ω... however, you've got the power issue to contend with then.
That is presuming that the bins are 8Ω. Edited by djeddie - 05 September 2012 at 10:37pm |
Creative
Registered User Joined: 05 February 2009 Location: Southend, Essex Status: Offline Points: 139 |
not to mention that some of the amp's power will be split over the two series bins whilst the one in parallel will be trying to cope with the all the rest by itself!
Time flies like an arrow - fruit flies like a banana!
numtie
Young Croc Joined: 06 November 2008 Location: wales Status: Offline Points: 585 |
never mind the fact 2 of the drivers will recive more power than the third
Disco Hire Wales
numtie
or at least i think thats right
Disco Hire Wales
numtie
well i suppose it depends on which has the less resistance the single alone driver or the 2 wired together... and yay tripple post
Disco Hire Wales
Creative
the single bin will have half the resistance of the two series bin so it will be stuck with most of the amp power. Not a good idea. Either only use two bins or get another to make four. Then wire them in series/parallel.
crystal.a
so with the right amp choice with a little headroom it is a possibility or am i just going to blow a driver/amp, trying to build this system on a budget as i had to sell my last rig for financial reasons.
crystal.a
little more info i want to run 3 HD15's a side so 6 in total
djeddie
What amp are you planning on using?
crystal.a
possibly a matrix xp5k not a 2 ohm stable one though
numtie
hmm no easy solution i think the choices are
drop 2 of the hd's to run two aside get another 2hd's get an amp that will run 2ohm stable or get a second amp to run 3 pairs
Disco Hire Wales
