Setting up AVC2s & multiband compression |
Post Reply | Page <1234 6> |
snowflake
snowflake
looks like sabine don't make those units any more. ClearOne website just lists two feedback eliminator models under the Sabine brand.
MattStolton
Sabine as it was is long gone. They started fecking about with digital radio mics, which caused them to move from core good stuff.
Sabine name was bought by the far east..... Ebay? I picked up my PowerQ from there, similar but different
toastyghost
We've got two PowerQ somewhere on the shelf, wish we had the AES cards for them and one has a slightly wonky screen but they're nice bits of kit - when you know how to use them and avoid the auto filtering going absolutely bonkers!
tv00
Old Croc Joined: 10 August 2009 Location: Denmark Status: Offline Points: 1886 |
But I don't think I need any real-time surveilance by cams or mics, it's much simpler, almost happens by itself: As the night moves forward the dj pushes the soundsystem more, so any conventional dynamic eqq should be able to do that, simply by putting an eq on let's say 4khz with a broad curve and a threshold matching the level were it becomes too much.
My question from the beginning is what the avc actually does when set to a- weighted curve: does it sense a-weighted or spit out a-weighted, if it is the last, then it's perfect:-) Otherwise I'll consider different dsp-presets or perhaps a crossfader between input a/b & c/d, but this solution means that one of the input pair would have a lot of eq, by having different presets I can adjust the output gains instead... |
4D
If you have someone on site who can reliably operate a switch selecting different presets then a jellyfish sw9010 & a Bss Soundweb 9088ii is probably the most flexible and more affordable option that will provide secure control Alternatively one of the Bss London Blu series will allow automatically switched presets to be assigned to different times of the day reducing the chance of operator error |
snowflake
I think the AVC2 senses a-weighted - so it is less sensitive to bass. and then does uniform gain reduction when triggered. |
tv00
Thanks for that answer, after all it's the first question, if it does I need nothing else, yet you "think", I wrote an e-mail to Ian there actually, sometimes it takes a while to get a reply
King George
Registered User Joined: 18 January 2011 Location: South Status: Offline Points: 334 |
I've never done it, but some sort of thermistor input into a Soundweb?
Selects an approximate audience size preset as the room temperature increases...
tv00
Well, it's all more simple, the dj turns up the output when it's filling up, then it needs to gain less on highmid than the rest...
shagnasty
So easy to do with a Soundweb and VERY hard to achieve without, literally a couple of wires and Pot on the control port of a Soundweb would let you smoothly move from "empty" setting to"full settings... The more stuff I do, the more I realise there is only Soundweb and the rest is SO limited....
tv00
No need for complex solutions to simple problems!
There's no need for any mics, thermometers, extra buttons etc. An avc turning down a-weighted would be perfect, next best is just a dynamic eq, more dsp setting might be better acoustiacally, but not as simple as noting for the dj to do but turn up & don't worry |
