Show Me Your HF Horn Boxes |
Post Reply | Page <1 78910> |
Venny14
Registered User Joined: 05 November 2013 Location: Downham Market Status: Offline Points: 61 |
What trailing cable did you use for making the Speakon loom?
Because thats how I like to do things, Thats why.
njw
Old Croc Joined: 26 March 2010 Location: S. Wales Status: Offline Points: 2572 |
Teunos
@Timebomb, yes that is a piece of foam. I made the picture when i was cleaning the workshop/storage as it has gotten very dusty from the sanding of some cabs. The foam is there to keep out dust.
the speakon loom is a 8x2.5 tasker cable from NL8 to a split box. The split box is set up channels like this : A, A, B, B, C, D, A+B, C+D where A,B,C,D denote the channels from the amps. It lets me use 4 different channels or either use 2 biamped cabs, such as the MH212 and the HF horn boxes that house the 4590's. The tails from the splitbox to the cabs are PVC jackets 4x2.5. I also have 2 separate split boxes with an NL8 chassis in, instead of a fixed cable. Edited by Teunos - 16 February 2014 at 2:04pm |
Best regards,
Teun. |
Biggus
Young Croc Joined: 02 May 2010 Location: Market Harborou Status: Offline Points: 1284 |
So I started this post four years ago, only just got round to getting the top boxes done but here they are. |
all bass
Did you grow the trees for the box yourself these past 4 years? Better late than never mate!
Biggus
Rome wasn't built in a day! I got side tracked and built monitors bass cabs upgraded the lighting and amp rack in the interim. ha!
Ras Loud
Young Croc Joined: 08 January 2012 Status: Offline Points: 754 |
Then you should also change the handle on the top, because these spring type handles can break off quickly when the box is too heavy. |
Audio_Stash
Registered User Joined: 02 June 2014 Location: UK Status: Offline Points: 245 |
bitSmasher
Old Croc Joined: 23 June 2012 Location: Melbourne Status: Offline Points: 2296 |
Which horn is that? Trying to get a sense of scale
DMorison
Old Croc Joined: 14 March 2007 Location: Aberdeen Status: Offline Points: 1647 |
Mounting hole pattern, and scale relative to the handles make it look a whole lot like the PH-4220. |
Audio_Stash
Correct ph4220
bitSmasher
Exactly what I thought, the PH4220 is apparently a copy of a Beyma TD250
I'm looking to buy a few of those horns on clearout special ($15 here!), how low do you cross them and how do they sound? |
