  New Posts New Posts RSS Feed - ----Show Off Your Heftiest Woofer-----
 Post Reply Post Reply Page  <12345 13>
asaa00 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote asaa00 Quote  Post ReplyReply Direct Link To This Post Posted: 17 June 2010 at 9:13pm
a mod or the OP should rename this thread "-=SHOW OFF YOUR DRIVERS=-" and just keep the pics comin'guys......
rich_gale View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rich_gale Quote  Post ReplyReply Direct Link To This Post Posted: 17 June 2010 at 9:18pm
fixed.  would be nice to see shots showing off the mechanics of all the main drivers.
RosscoPico View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RosscoPico Quote  Post ReplyReply Direct Link To This Post Posted: 17 June 2010 at 9:35pm
Massive Audio subs look good (for car subs) IMO:
.:ELEMENT 5 SYSTEMS:.
djshaney View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote djshaney Quote  Post ReplyReply Direct Link To This Post Posted: 17 June 2010 at 9:50pm
why do all car audio companies have such cheesy names LOL
JR.junior View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JR.junior Quote  Post ReplyReply Direct Link To This Post Posted: 17 June 2010 at 10:26pm
CV-Stroker Pro 12"!
Sinfinity View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sinfinity Quote  Post ReplyReply Direct Link To This Post Posted: 17 June 2010 at 10:29pm
Big woofer
Edited by Sinfinity - 17 June 2010 at 10:30pm
Matt at ukamp dot co dot uk
Post Options Post Options   Thanks (0) Thanks(0)   Quote JR.junior Quote  Post ReplyReply Direct Link To This Post Posted: 17 June 2010 at 10:38pm
Hug EPIC!!
Posted Image
Post Options Post Options   Thanks (0) Thanks(0)   Quote asaa00 Quote  Post ReplyReply Direct Link To This Post Posted: 17 June 2010 at 11:16pm
hahahaha good woofer pooClap
Edited by asaa00 - 17 June 2010 at 11:16pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote rich_gale Quote  Post ReplyReply Direct Link To This Post Posted: 18 June 2010 at 7:43am
Originally posted by JR.junior JR.junior wrote:
Hug EPIC!!
Posted Image
i just died.Clap
Oscar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Oscar Quote  Post ReplyReply Direct Link To This Post Posted: 18 June 2010 at 9:33pm
so when it says "show off YOUR heftiest woofer", shouldn't it be woofers that people actually own, instead of just showcasing what people can find on the internet? Smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote Oscar Quote  Post ReplyReply Direct Link To This Post Posted: 19 June 2010 at 4:01am
hey oscar.  please can you check something for me..
if you unscrew the three allen head bolts on the back plate of your blown stroker 18, does it allow you to remove the back plate?  or is it glued?
i have another stroker with some rust buildup in the vc gap and i want to see if its possible to get at the vc gap to clean it up without a full reconing
good question.....I have not been able to check that since my tiny allen wrenches will not allow enough leverage to loosen those bolts.....what's preventing you from checking yours?
Post Options Post Options   Thanks (0) Thanks(0)   Quote rich_gale Quote  Post ReplyReply Direct Link To This Post Posted: 19 June 2010 at 9:42am
i dont want to go losening them and ruining the coil of a woofer that might not need a recone.  if i can get to it easy i can clean and vacuum out the vc gap from the back.  otherwise i think i might open up the central spindle hole (in the center of the front spider) a bit with a scalpel and get a thin vacuum nozzle in there while running a 20hz signal free air.  i will make the hole in the front spider small enough so it is covered back up once the centering ring is screwed back in place.
its not a terrible rubbing noise from the rust, but enough to annoy me.
any ideas before i go and order a recone kit?
Edited by rich_gale - 19 June 2010 at 9:43am
