  New Posts New Posts RSS Feed - -=SHOW OFF YOUR SOUND SYSTEM!!!!=-PART 2
Topic Closed-=SHOW OFF YOUR SOUND SYSTEM!!!!=-PART 2
 Post Reply Post Reply Page  <1 538539540541542 690>
 Rating: Topic Rating: 5 Votes, Average 5.00  Topic Search Topic Search  Topic Options Topic Options
fourway hornloaded View Drop Down
Direct Link To This Post Posted: 16 March 2014 at 7:48pm
AvLee View Drop Down
Direct Link To This Post Posted: 16 March 2014 at 8:14pm
Hey man, what are those 3 way tops? And I'm guessing the HF's are rotatable?
Direct Link To This Post Posted: 16 March 2014 at 8:17pm
Limmer P3. That's one of Limmer 085 and 042 each. Limmer 042 is square and rotatable.
Direct Link To This Post Posted: 16 March 2014 at 8:21pm
Nice!
tv00 View Drop Down
Direct Link To This Post Posted: 18 March 2014 at 12:09pm
I better contribute to this thread, I've had a few different rigs.
This is one out of four stacks, Sometimes I use them with hybrid subhorns below to go all deep.
I usually lowcut the pictured stack at 34-38 hz depending on room response.
System loaded with: fane 18-1500,- rcf mb15n401, turbosound ls-1004, bms 4540nd.
In action with subs last year, before it was painted:
Edited by tv00 - 18 March 2014 at 12:16pm
cravings View Drop Down
Direct Link To This Post Posted: 18 March 2014 at 1:26pm
nice! have you posted about those array boards / separators you've made before?
tv00 View Drop Down
Direct Link To This Post Posted: 18 March 2014 at 3:39pm
You mean for splaying? It's very simple, but I need to make some dedicated stack boards.
Right now I'm using a 4X4" or 2X4 for tilt & some plyboards with triangles behind for splaying.
Pretty simple but It looks good, my friend did the ply-pieces & painted them black.
As you can see I used two ratchet straps, one around them from bottom up & around the cluster to secure them from sliding. With a stackboard I wouldn't need any of this, I would simply strap the board with the bassbins & strap the tops to the stackboard.
Ibex View Drop Down
Direct Link To This Post Posted: 18 March 2014 at 6:55pm
Originally posted by fourway hornloaded fourway hornloaded wrote:
Please, tell us more about your bass bins!!! ^^
corell View Drop Down
Direct Link To This Post Posted: 18 March 2014 at 7:46pm
Should be a symmetrical 6.order Bandpasshorn
Direct Link To This Post Posted: 18 March 2014 at 7:57pm
6th order band pass horns. Vented back chamber, quite large front chamber, large throath and then into a 75cm horn. Hornresp makes it possible! :-) You need to keep the group delay curve reasonably flat, which basically means keeping the response flat. No peakyness. The horn part is short, exponential and braced over its entire lenght. Nice and tight. Many basshorns aren't braced enough, to my taste, which makes them sound woody, so people tend to cut them off low. I use these from 35-180 Hz. They do a bassreflex-like deep bass but they hit your throath as well. Like two-way bass.
soundguymatt View Drop Down
Direct Link To This Post Posted: 18 March 2014 at 8:07pm
How many do you need to keep up with your tops for live music type stuff?
Matt
Ibex View Drop Down
Direct Link To This Post Posted: 18 March 2014 at 8:24pm
Well done bro!
May I ask which 18" (?) driver you're using and how big these babies (cabs) are?
...it's been a while since something interesting new and well designed was posted up here, unfortunately!
This page was generated in 0.453 seconds.
