-=SHOW OFF YOUR SOUND SYSTEM!!!!=-PART 2 |
Post Reply | Page <1 551552553554555 690> |
Pasi
Old Croc Joined: 25 April 2010 Location: Knutsford Status: Offline Points: 2732 |
Posted: 21 April 2014 at 11:49am | |
Not him, the other guy. If it would have been the guy you're thinking of, PUKK actually wouldn't make any bass. |
Battered
Registered User Joined: 19 January 2013 Location: S.W. LONDON Status: Offline Points: 461 |
Posted: 21 April 2014 at 11:58am | |
PMSL
simon_16v
Registered User Joined: 30 May 2013 Location: Nottingham Status: Offline Points: 18 |
Posted: 21 April 2014 at 4:15pm | |
My current system: Only used a handful of times. Sounds pretty good. Runs on 2 Yamaha p7000s Amps and BSS management.
norty303
Posted: 22 April 2014 at 5:51pm | |
Invert the lower bass cabs and get the ports all together
Grinner
Registered User Joined: 02 December 2005 Location: essex Status: Offline Points: 407 |
Posted: 22 April 2014 at 6:52pm | |
what if the lower cab was running lower an the same cab higher in the stack was playing higher than the other(more kick) an besides that. i though you got more bass extension from having the ports on the ground? |
all bass
Posted: 22 April 2014 at 7:02pm | |
True, but ports coupling to eachother will help even more.
simon_16v
Posted: 22 April 2014 at 7:17pm | |
I have tried that before, but didnt really notice much difference. I figured it would be better to have ports on the ground.
csg
Posted: 22 April 2014 at 7:30pm | |
ports will couple at that distance at the frequencies they will be working at. the sub will also couple to the ground in half space just fine too.
Grinner
Posted: 22 April 2014 at 8:55pm | |
i remember reading a test between a letter box x1s an standard x1s
rog was present an said the letter box 1 slightly edged it because of more port in contact with the ground.(ports being slightly wider in letterbox version). |
king david
Young Croc Joined: 17 January 2007 Location: italy Status: Offline Points: 1324 |
Posted: 22 April 2014 at 9:22pm | |
while i must say the system looks very nice, all the time i see the subs as stacked in the picture, i cant stop thinking you have very nice respectful dancers too, because if i stack my hogs like that, the drivers in the bottom ones would not last long in normal condition... |
cravings
Posted: 22 April 2014 at 9:48pm | |
the scoops look like they have full grills on them to me.
tv00
Old Croc Joined: 10 August 2009 Location: Denmark Status: Offline Points: 1886 |
Posted: 23 April 2014 at 8:40am | |
More than cones? I guess ports couple more low end than cones as they're designed to extend this. What if the top cab was flipped to couple the cones movement? Then ones ports would be on ground, A lot of cabs are like this too I've seen. |
