-=SHOW OFF YOUR SOUND SYSTEM!!!!=-PART 3 |
Post Reply | Page <1 2930313233 95> |
unclejam
Young Croc Joined: 14 January 2006 Location: United States Status: Offline Points: 525 |
concept-10
Young Croc Joined: 17 May 2016 Status: Offline Points: 1292 |
good man 😀
Teunos
Looking good.
A piece of friendly advise; if you can, upgrade too an as large flare as you can fit in there. The bigger the horn, the better the directivity will be controlled towards the lower end of the spectrum. On the baffle there is plenty of room for a bigger one, so why not use it? Also a bigger horn will load the compression driver better down low, making it easier to use a lower crossover frequency. |
Best regards,
Teun. |
cravings
good work indeed. another note on the horn flare.. the top of the box protrudes quite far, so check that the angle of your horn won't "hit" the top of the box. i've long thought it might be worth building the mount for the flare at a 10 degree angle or so.
unclejam
I'll keep that in mind when I decide/can afford to upgrade the horn driver and shoot for the bms4590 to really make these shine. Also cravings I think I'll be fine as they are only 60x40 lenses.
toastyghost
Some girl called Nina Kraviz played a few tunes on a slightly too large soundsystem at Hope Works in Sheffield on Friday. You can even see me doing something in the background! It were pretty good Edited by toastyghost - 12 June 2017 at 2:18pm |
Risc_Terilia
Young Croc Joined: 15 December 2007 Status: Offline Points: 689 |
Sorry didn't see this question. The 6" is 75 degrees. |
IainB
Registered User Joined: 25 November 2016 Location: Rushden Status: Offline Points: 422 |
Latest incarnation... though stuffed my back getting the tops up there
Next time out, I need to spin the kicks 90 deg so the mouth is orientated correctly
toastyghost
It won't make any difference to the output with just two of them if that makes you feel any better.
luton_soundman
Old Croc Joined: 03 August 2010 Location: Bedfordshire Status: Offline Points: 4538 |
Some of BALLISTIC ROOTIKAL NEW BASS/MID/HIGH's
gen0me
Nice! What are the crossover points and speaker sizes?. Any simulated charts for mid? What are those hf horns? Hope it sounds nice.
Edited by gen0me - 15 June 2017 at 8:59pm |
ubersafka
Registered User Joined: 11 April 2017 Location: Finland Status: Offline Points: 15 |
Finished building my speakers last week, i still have grilles to fix. First speakers Ive built, and everything works as should now.
2 x Fane Colossus 18 XB, 2 x Fane Sovereign 12-300 & 2 x BMS 4554 1.4" compression drivers. I am using Crown XLS 5000 for the subs, t-amp tsa 4700 for mids & highs and behringer ultradrive pro dcx2496 & soundcraft epm-6. |
