Show us your Distro.. |
Post Reply | Page 123 5> |
razorray
Registered User Joined: 06 December 2005 Location: London Status: Offline Points: 425 |
Posted: 30 September 2013 at 3:28pm |
ruelectrical
Registered User Joined: 03 February 2011 Location: Gloucester Status: Offline Points: 269 |
I recognise the 63 amp distro, glad its been put to good use, PAT labelling is a bit out of date !!!
razorray
James Tengo
Old Croc Joined: 09 May 2008 Location: Brighton Status: Online Points: 2155 |
Bit quiet in here so I thought I'd join with a compact system I'm currently touring
This is a Coloursound BT Distro, based loosely on their S type distro, but with individual RCOB's per outlet, designed to run their LED walls (BT = Big telly, their video walls are all named BTx, where x is the pixel pitch) 63a 3ph input, 32a 3ph outlet (motors usually, dimmer in this application) 3x 16a 1ph outlets (control usually) and 3x socca outs. Rear shot Chamsys at FOH And a bit of desk porn for the rest of you, H2000 house desk, Pro6 touring desk, supplied by BritRow Walk in state, Ancienne Belgique in Brussels, one of my favourite venues in Europe |
GAZ.
Old Croc Joined: 16 January 2007 Location: Hertfordshire Status: Offline Points: 2433 |
I've got 4 EMO distros, 3 with 8 13a sockets on and 1 with 4. All now converted to powercon inputs and used in racks.
I've also got 2 kelsey's 1x PD7/32 [old type with 3 sockets on the front, newer ones only have 1] ] And a PD7/16, Same as above but 16a input and link for those that dont know! And a Rubber Box RUB1409C |
100% Earth Moving Bass
James Tengo
An old shot here, from Soulwaxmass 2011, dimmer beach, consists of a D type distro (known as the daddy distro, which is 400a powerlock in and thru, 1x 63a 3ph out, 2x 32a 3ph outlets, 12x socca outlets, 6x 16a 1ph outlets, 3x 32a 1ph outlets and 2x 13a outlets) an L type distro (L for leftfield, originally made to run a lot of diversitronics strobes, pre martin atomic, each needed a 32a 1ph feed, so it has powerlock in and thru, and 9x 32a 1ph outlests, 3x soccas and 2x 32a 3ph outlets) a BT distro, and an avolites art 2000 dimmer, (48ch) and two strand act 3 (5kw/ch) dimmers. In the background is motor control world
Adam_Iron_Horse
Old Croc Joined: 02 January 2010 Location: Scotland Status: Offline Points: 2043 |
Custom built by a forum member
3 20A rings with 2 Powercon on each 1 10A ring with 2 IECs 1 5A ring with 2 IECs 1 16A ring with powercon on the front |
razorray
AM55
Old Croc Joined: 16 August 2007 Location: Matlock Status: Offline Points: 1728 |
razorray
remove sprung cap from plug
adyk
Registered User Joined: 05 May 2009 Status: Offline Points: 442 |
Edited by adyk - 09 October 2013 at 1:34pm |
QSS
Old Croc Joined: 21 July 2009 Location: Bristol UK Status: Offline Points: 2414 |
"Music is life"
