  New Posts New Posts RSS Feed - Simplified MT121 Plans
levyte357 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357 Quote  Post ReplyReply Direct Link To This Post Topic: Simplified MT121 Plans
    Posted: 16 April 2008 at 10:44pm
For those of us who weren't aware they were here.
Originally posted by Three-Bee Three-Bee wrote:
img218/8403/tdamt121gk5.jpg
Originally posted by TDA-Audio TDA-Audio wrote:
mt121 my version
Edited by levyte357 - 16 April 2008 at 11:02pm
Jake_Fielder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jake_Fielder Quote  Post ReplyReply Direct Link To This Post Posted: 16 April 2008 at 11:20pm
Well done lev, it took me a while to find that plan when i was looking for it the other day actually.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jake_Fielder Quote  Post ReplyReply Direct Link To This Post Posted: 21 April 2008 at 12:11pm
Where did it go three-bee?
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357 Quote  Post ReplyReply Direct Link To This Post Posted: 28 April 2008 at 1:12pm
Next question.
Can someone put up hornresp data for this?
Plans say it will go upto 1.6khz, but I'm sure its starts falling off sharply at approx 900hz.
My initial guestimations,
Horn length=47.8cm, Vrc = approx 11 litres,  S1=360 sqcm,  S2=1911cm2.
Mark James View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark James Quote  Post ReplyReply Direct Link To This Post Posted: 28 April 2008 at 1:45pm
horn response wont model well after about 400hz iirc. 800hz seems to be the usual crossover point according to users. maybey the mods would make it play heigher??? I doubt it that much though to be honest.
If you want people to feel the bass then a reflex design is probably best as you get the most air movement per decibel from those.      errrrr yes wtf?
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357 Quote  Post ReplyReply Direct Link To This Post Posted: 28 April 2008 at 2:25pm
OK.. Just what I was thinking...
Gonna be a bit cheeky here Wink, and ask peeps to estimate what size chamber, throat, horn length would be needed for 15" straight horn to fit below MT121 section in same cab?
The 15" section would ideally handle 90-160.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark James Quote  Post ReplyReply Direct Link To This Post Posted: 28 April 2008 at 2:46pm
could maybey extend the selenium horns from the pas series??? they only do 120hz though...
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357 Quote  Post ReplyReply Direct Link To This Post Posted: 28 April 2008 at 2:54pm
No pulling the wool over your eyes mate, thats exactly what and why I'm asking!!!!
The Selenium plan alledges 120-300hz, I guess it would require larger chamber/throat and longer horn to drop top 80hz.
Edited by levyte357 - 28 April 2008 at 2:55pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark James Quote  Post ReplyReply Direct Link To This Post Posted: 28 April 2008 at 3:32pm
I cant see why what your asking cant be done, might end up a bit bigger than youd have hoped for but I cant see any reason it couldnt be done lol.
markk
Heathrow_B_line View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Heathrow_B_line Quote  Post ReplyReply Direct Link To This Post Posted: 28 April 2008 at 6:50pm
why not start from scratch?
you have moved away from the original design anyway
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357 Quote  Post ReplyReply Direct Link To This Post Posted: 28 April 2008 at 7:18pm
Yes, but I guess it will stil be compromise on the 15" section; 25cm deep rear chamber + 60cm horn, and we are already talking cab depth over 80cm.
If I knew exactly how to sim the Selenium 15+12 trap, it would be much easier design from there.
TDA-Audio View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TDA-Audio Quote  Post ReplyReply Direct Link To This Post Posted: 28 April 2008 at 9:13pm
\\\\\\\The 15" section would ideally handle 90-160.\\\\\\\
yez (60-80 -- 140-160)
\\\\Selenium 15\\\\\\
no - not work 60-80 hz...
smoll mouth. and short  horn...
hd-15  may be...
