Simplified MT121 Plans |
Post Reply | Page <1234> |
boycey
Old Croc Joined: 25 June 2006 Location: Manor House Status: Offline Points: 1612 |
the dispersion quoted is identical to the original plan, has that been tested? (scientifically or otherwise?) i was under the impression that this is what will change with the simplified plan.
the only thing more dangerous than a person who doesn't give a f**k is a person who gives a sh*t.
levyte357
The 10,000 Points Club Joined: 10 May 2004 Location: UK, London Status: Offline Points: 11743 |
Personally, I think easiest scenario is cab that comprises the following
2" Driver 900 -> 10Khz
MT121 160->900hz
1/2 USB 80->160Hz
Unfortunately, will be square cab due to unmodified USB section, similiar to following,
Will need bullets/supertweeters to get that 12k-20khz sizzle, or very expensive Beyma 1.4" 755 series.
Anyone fancy drawing this up? Edited by levyte357 - 30 April 2008 at 12:36pm |
josh
Registered User Joined: 03 December 2006 Status: Offline Points: 682 |
i was thinking about this lev and i think with a bit of thought it could easily be made trapezoidal. however im not going to bother wiht it, i prefer the idea of the midtop and the mickbins being seperate, them being together will probably result in a lot of wasted space too.
Tekasis
Old Croc Joined: 03 July 2006 Status: Offline Points: 6492 |
Any update on this idea ?
**Heavy Weight-Line**
A home without books is like a body with no soul. |
mylesound
Registered User Joined: 08 August 2007 Status: Offline Points: 351 |
Im also intrested in this 3 way.
I was planning on buying DDS 12"&2" fiberglass mold horn and building some HD15s with longer side and rear pannels to house the 2 horns. Its almost the same thought. |
Deadbeat
Old Croc Joined: 12 March 2008 Location: Singularity Status: Offline Points: 3167 |
Hmmm... reinventing the TMS series, are we?
I'll try to get drawings up by the end of the week for you guys. |
Away on extended leave.
AdiRCF
Registered User Joined: 22 June 2006 Location: Romania Status: Offline Points: 162 |
I'm so tired to see on this forum this cliche. " oh sh*t, we need bullets or very expensive beyma drivers " Has enyone of you tried the 2" exit driver wnd-72 from P.Audio ? I've got 4 of them and i'm verry pleased with them. they can be cut low and they go like crazy in the upper region Edited by AdiRCF - 25 June 2008 at 12:54pm |
Sughi Bughi
Deadbeat
I can get that very cheaply. But i don't. Want to know why? Because I'm of the opinion that it sounds absolutely horrible. But that's just my opinion. I always buy the BMD and SD series of comps, at a minimum. Would take a BMS (if they're in Malaysia - never seen them over here, but heard them in England), Beyma or another superior comp even if I had to import one. Besides, it is the horn + comp that counts. I could put a crap comp on an excellent horn, and it would sound decent, and i could put an expensive comp on a crappy little horn and it would sound horrible. Edited by Deadbeat - 25 June 2008 at 1:51pm |
Tekasis
Are they new ? Can't see them on PAP website, how much are they ?
Tekasis
It must definately be the difference in what people hear, as many on here say the BM-D series also sounds sh*t.
I keep hearing very good stuff about the Beyma CP-755Ti's, & if they're as good as they make out, the BM-D750's will have to take a back seat!
AdiRCF
I heard only bad things about this driver. After 10 Khz it drops and it needs a bullet to take over the upper region or some serious gain with the eq. |
Sughi Bughi
Deadbeat
Different ears, maybe.
I don't think the WN series is available over there. Check out loudspeakersplus for the prices in USD. WN-series isn't new, I think. |
