Small VC, low power, high efficiency 18" drivers? |
Beast
Registered User Joined: 20 June 2012 Status: Offline Points: 31 |
Posted: 08 December 2016 at 11:41pm |
Hi Guys...
I have some fresh JBL 2360 cinema horns loaded with 2450 2" comps. I'm happy playing down to 500hz with these suckers and am looking for some neo 18" drivers that will play up to 500hz and have a 99-100db/1w sensitivity. I'm thinking 3-4 18" cones per side - individually boxed, closely coupled in a vertical line array which in previous experiences (with 2206H 12" cones) couple and are very directive. scaling up to 18" cones i'm hoping shifts some more air. the system will be run from 12v so 4 8r cones per side will get me 2r per side. please... your suggestions for lightweight, fast 18's!!! |
lickweed
Old Croc Joined: 02 May 2009 Location: leyton Status: Offline Points: 2489 |
stick with 15"
If you really want to use 18" this one might work at a push
http://www.liquidsound.co.uk/
ceharden
Or try and find some old EV DL18MT's. 2.5" VC's, very light cones for an 18". Not much good for bass compared with modern drivers but for what you're doing would be ideal.
Beast
are there any 15" neo drivers as good as the 2226h?
shaun1264
Registered User Joined: 06 September 2013 Location: Surrey Status: Offline Points: 292 |
15" JBL 2227
Beast
Come on man..:) We all know the 2227 ain't a proper replacement for the 2226h! |
Karlsonman3
New Member Joined: 07 April 2012 Status: Offline Points: 3 |
the old EVM18B had mms less than 80g, here's my sample playing 2-way to a slotted pipe tweeter poking into the front chamber of a Karlson coupler. IIRC, xmax as 3.2mm and remember seeing one bottom out in a reflex. The K-coupler seems better in that regard.
https://www.youtube.com/watch?v=XYsdJZA7coE
bitSmasher
Old Croc Joined: 23 June 2012 Location: Melbourne Status: Offline Points: 2295 |
This is interesting- 12v, is it portable?
Care to post some pics? I'm contemplating similar, big horn run down to <1khz with 3 reflex 12s underneath |
