SoundBarrier DRAGON18-2200 compatible with YAMAHA |
| Author | ||||||||||||||||||||||||||||||||||||||||
csijo
Joined: 28 March 2005 Location: Venezuela Status: Offline Points: 55 |
Topic: SoundBarrier DRAGON18-2200 compatible with YAMAHAPosted: 02 February 2012 at 8:21pm |
I appreciate your help I want confirm if the low Sub SoundBarrier Dragon18-2200 is compatble or works fine inside the acoustic box of SW118V Yamaha subwoofers. The original lows yamaha was damaged and would like to use these Dragon in these boxes and do not know if I get a good performance. I want hear their expert opinions. thanks Jose Ortega from Venezuela Sound Barrier specs: Nominal Diameter: 18” Nominal Impedance: 8Ω Program Power Handling: 1100W Maximum Power Handling: 2200W Sensitivity: 96dB Frequency Range: 38Hz-2.2 KHz Voice Coil Diameter: 5” Voice Coil Material: Copper & CCAR Former Material: Glass Fiber Magnet Size: 200 Oz. Frame Material: Cast Aluminum Net Weight: 50 lbs (22.68 Kg) YAMAHA SPECS: Size/Weight
Specifications
Audio Fanatics, Bass lover
Nitz V1505
Joined: 16 September 2009 Location: UXBRIDGE Status: Offline Points: 1291 |
Posted: 02 February 2012 at 9:37pm |
Shortman in Venezuela?!!!!! Doing drivers?!!!!
& THE TOPS LIKE LIGHTNING..... |
Smiter
Joined: 21 August 2010 Location: UK Status: Offline Points: 1169 |
Posted: 02 February 2012 at 9:57pm |
didnt he go on the run?
csijo
Posted: 04 February 2012 at 1:42pm |
Friend
I only want to know if the drivers Sound Barrier Drago works fine in the box of the yamaha Subs. Is the only thing |
csijo
Posted: 04 February 2012 at 1:43pm |
Tweet
