Speaker front foam |
Post Reply | Page 12> |
jerronimo
Registered User Joined: 11 July 2009 Location: Nederland Status: Offline Points: 438 |
Posted: 23 May 2015 at 6:17pm |
I'm in the process of building some tops, and would like to use a grille and speaker-foam for protection, and a nice finished look.
So I bought this stuff: This is advertised as speaker foam thickness is 10mm but seems to me that it's way to dense, i'm afraid it will block to much sound from the tweeter?
Hemisphere
It won't - That stuff is designed to let all freqs through fully
Dub Specialist Sound
It looks like amplifier fan grill foam to me
is it the same stuff then?
Edited by Dub Specialist Sound - 23 May 2015 at 11:54pm |
jerronimo
Well, I tested it on some home speakers, and it seems it does block high frequencies from the tweeter...
AM55
Old Croc Joined: 16 August 2007 Location: Matlock Status: Offline Points: 1728 |
Do you know how many pores per inch it is? It should have a PPI rating.
I think 35 is common and turbosound used 40 on the old TMS range. The lower the ppi the corser it will look. Maybe PM Markie and get his opinion. |
markie
Old Croc Joined: 31 October 2005 Location: Sunny Liskeard. Status: Offline Points: 4570 |
The one I use is HiFi35 which is 35ppi and is the industry standard. As far as I know the old Turbosound stuff was 30ppi not 40 but they fitted it in 25mm thick so 10mm shouldn't make a lot of difference.
I also sell a lot of custom made foam fronts for classic HiFi speakers and believe me when I say these guys are PICKY. I don't get any complaints about this from my customers. Having said that I can't tell anything from the picture. It's supposed to be open cell foam and held up to the light you should be able to see through it (A bit like a "Starry starry night". If you can't then it's the wrong stuff. |
markie
If you want to PM me your address I'll send a small sample for comparison.
AM55
I stand corrected. My memory is shite.
Mircea Bartic
Old Croc Joined: 18 February 2005 Location: Romania Status: Offline Points: 2582 |
Thanks(1)
Inspired by your question I took some measurements a few minutes ago:
I used a OEM coaxial speaker in free air placed on the ground with the measurement mic place at 1 meter above the HF horn exit. First I measured the speaker without foam then I added 8mm thick foam The graphs look like this Red graph = 8mm foam added blue graph = no foam click here for larger graph : http://i61.tinypic.com/28s4pd3.jpg I the repeated the experiment using 2 sheets of 8mm with a total thickness of 16mm The resulting graph looked like this: Red graph = 16 mm foam added black graph = no foam click here for larger graph: http://i62.tinypic.com/289zc4h.jpg Edited by Mircea Bartic - 24 May 2015 at 3:07pm |
all bass
Thanks for the fast measurements Mircea. Really helpfull!
@OP Is that speaker grill foam or some other open cell foam like as used in kitchen extraction etc? |
Mircea Bartic
By the way, the foam measured was the type we use in production. Large cell open type like on the Dynacord Xa2
as you can see in the graphs , you could put over 50mm thickness before measuring any attenuation even at 20Khz |
Thanks for the Share too, very interesting not just for the OP
