speaker wiring bass bins |
Post Reply | Page 123> |
2x18
Registered User Joined: 03 April 2008 Status: Offline Points: 201 |
Posted: 10 September 2008 at 9:20pm |
ok how would you wire 4 cabs 2x 18" in each with 2 amps ?
2 x sr707s 825w into 2x 18" (4 ohm cab) per channel - and lose input signal from active crossover or 2 x sr707s each bridged into 2 cabs in series (2 cabs would be 8 ohm ) - and not lose input signal from active crossover cannot run 707s at 2 ohms thanks |
just a old dj
Deadbeat
Old Croc Joined: 12 March 2008 Location: Singularity Status: Offline Points: 3167 |
what do you mean by 'lose input signal from active crossover'
Away on extended leave.
2x18
when linking 2 amp inputs together you lose a slight amount of signal due to them being spit
just a old dj
2x18
just a old dj
Sheggy
Old Croc Joined: 23 May 2008 Location: London Status: Offline Points: 1991 |
I've never had to do this but if your power amps input impedence is sufficiently high then the loss in signal should be negligible no?
S |
al_x
Young Croc Joined: 12 February 2006 Status: Offline Points: 834 |
* beginners section
and you wont lose signal if you daisy chain the amps once (thats assuming the amps have an input and output) |
2x18
so still no answer on should the amps be bridged or not ?
just a old dj
the smf
Registered User Joined: 08 May 2008 Location: United Kingdom Status: Offline Points: 761 |
ur not to clear on this
if the amp is powerful enough per channel to give headroom, use it this way, if it isnt and u can only get the headroom from bridged mode then bridge it is
al_x
'2x18'
please start again. your very confusing! |
odc04r
You wouldn't be able to measure it with an extremely expensive oscilloscope. Perhaps if you linked 100 amps you might notice a small drop in input level. Edited by odc04r - 11 September 2008 at 12:55am |
extremeaudiopro
Registered User Joined: 30 August 2008 Status: Offline Points: 21 |
it really depends on how you link them as above stated if it has an output made for linking than no. but in the case of how i do it
crossover -> XLR inputs than from the 1/4 input -> 1/4 input of the other amp. you do notice a good deal of signal drop.
and for the guy who started this you need to repost your thinking again the way you describe it is a lil confuseing.
H...
Young Croc Joined: 21 July 2008 Location: UK Status: Offline Points: 1164 |
C-Audio SR707's have xlr in/out so just make 2 small xlr f - xlr m link leads.
4 x 2x18" cabs at 4ohms per cab - one cab per amp channel.
