Speakon NL4FX - a step backwards? |
Post Reply | Page 123 5> |
SteveAATW
Young Croc Joined: 04 September 2007 Status: Offline Points: 1173 |
Posted: 01 June 2008 at 4:58pm |
Possibly the most spod like question ever asked but does anyone else find that the NLF4X is harder to use, that the terminals don't grip cables as well and is just generally a big step backwards from the NL4FC?
toastyghost
Yes. It's a nightmare to squeeze 4mm squared cable in them and get it to stay in there.
I've been tempted to buy a load of these: http://www.neutrik.com/fl/en/audio/210_1380446656/NLT4FX-BAG_detail.aspx But the price is a little off putting. Edited by toastyghost - 01 June 2008 at 5:09pm |
SteveAATW
Yea £6 each is a bit OTT
Agreed on 4mm, only way i've got it to stay in reliably is to take the screw and grip out, stick a tinned cable end in and solder the full thing up, but even then because its recessed so much you have to be careful not to melt or distort the connector. If you needed to solder the 4FC at least all the copper housing was in plain view and you could get an iron on the whole side of it to heat it quickly and be done |
CLsystems
Old Croc Joined: 16 March 2007 Location: Birmingham Status: Offline Points: 2736 |
the easiest way i found was to unscrew the screw till its almost out, they use a small screw driver to push the tab inside the cable bucket so that its flat against the side, then put cable in and tighten. make sure theres enought bare end in there.
I dont like the connector release tab either, not as nice as the older style. sometimes ive found that the boot comes undone as you try to take connector out. |
Dom
Old Croc Joined: 25 February 2004 Location: United Kingdom Status: Offline Points: 1700 |
Thanks(1)
I unscrew the screw, throw away the tab and put the screw back in. Never had any problems with 4mm cables.
ceharden
Thing you have to remember with NL4FX is that they need a much longer bit of cable in the terminal than the NL4FC. If you follow the stripping instructions provided, I've never had any problems with the cable being gripped.
odc04r
You do need a fair bit of cable in them yes, I found this a while back. Close to a cm of stripped wire is good.
AlfieDring
Young Croc Joined: 04 September 2006 Location: Bath, UK Status: Offline Points: 842 |
Also surely if your going to solder it (the 4mm or larger sizes) you take the screw and tab out, split the cable end into two and solder one into the regular socket and the other into the screw hole. Wont ever come out again but then thats not the plan is it :P
Alf |
kevinmcdonough
Old Croc Joined: 27 June 2005 Location: Glasgow Status: Offline Points: 3749 |
yeah
i've never really had a problem with them, generally just strip an extra bit of the wire and make sure its stuffed right in there, and like someone said if your really struggling to fit the wire in, bend the little metal tab up a bit with a screwdriver first and seems to work, for me at least. k |
4DPA
Registered User Joined: 11 April 2007 Status: Offline Points: 1127 |
bs8901 compliant
opus jody
Young Croc Joined: 06 June 2006 Location: United Kingdom Status: Offline Points: 1246 |
recent tests we did showed that :
crimped connections sound better than soldered, metal spekons sound better without the metal case (some kind of field effect?)and not as good as the plastic ones. crimped connections on the spekon chassis also improve sound. some surprising results! i thought soldered cons would sound better due to the larger contact area - mai non! obviously tin & lead aren't as good as copper as a conductor. this is in the realms of the ultra fussy, but was enough difference for theatre sound designers to re-do all their existing spekons, where they always used to solder everything. practicalities like tougher spekons could be considered more important. i've never really had a problem with plasic spekons though, exept in a few installs where they've been used as steps to get up on the bass bins. |
Improvised Hardware Music http://vimeo.com/user9389813/videos
toastyghost
I've tried removing the little metal tab and screwing the cable in, and whilst it fits in better that way I found the cable is less secure and they've come loose after a while.
