Spot the deliberate mistake |
Post Reply | Page <12345 33> |
kedwardsleisure
Old Croc Joined: 20 January 2009 Location: Staffordshire Status: Offline Points: 4938 |
Yes FIVE different types of output transistor.
Using better ones on the repaired channel eg higher voltage versions of the regular transistor would be ok. We have MJ15022, MJ15023, MJ15024, MJ15025 and MJ15003. Maybe on a cheap disco amp it would be the only answer but a PM1000..and it didn't work anyway? |
North Staffordshire |
odc04r
Well maybe you get some spares out of it if they aren't all dead or counterfeit. Doubt the owner wants them back.
Earplug
"Yes FIVE different types of output transistor."
So designed to work over 5 different frequency bands! |
Peter Jan
Young Croc Joined: 16 December 2008 Location: Belgium Status: Offline Points: 1019 |
Nah... can't you see ? Someone made it into a 5-tier Class H design |
kedwardsleisure
Soft Start relay from Macrotech 5002VZ.
Complaint of mains transformer humming even with power switch 'off'. |
burningbush
Old Croc Joined: 25 May 2009 Location: Pictland Status: Offline Points: 5897 |
Vent hole conversion, runs cooler now.
mini-mad
..bass port?
Explains why they chug out bass all nite long... |
Earplug
Another bullet hole?
kedwardsleisure
it's been dinged by something but hard to see how, as it's pretty tight on the pcb and it hasn't been out before.
MattStolton
Someone shoved a screw driver into it, to try and separate housing from internal gubbings. Like how you remove engine oil filters on blocks, when stuck......
kedwardsleisure
Another modified macrotech
all bass
Trying to recreate the Belchfire i guess...
