  New Posts New Posts RSS Feed - sr 707
sr 707
2x18 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 2x18 Quote  Post ReplyReply Direct Link To This Post Topic: sr 707
    Posted: 29 December 2012 at 7:39pm
im gonna change my bass amp from a sr707 too ?
any suggests (  i thought about a crest ca9 )
what are your thoughts ?
thanks
just a old dj
Grubbah View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Grubbah Quote  Post ReplyReply Direct Link To This Post Posted: 29 December 2012 at 8:19pm
When you do, can i buys your 707 off you?
geronimo91 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote geronimo91 Quote  Post ReplyReply Direct Link To This Post Posted: 29 December 2012 at 8:20pm
1+ on that
Apache Hi Fi
krazyneil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote krazyneil Quote  Post ReplyReply Direct Link To This Post Posted: 30 December 2012 at 2:05am
what are you running speaker wise and whats your budget?
GOD TOLD ME TO DO IT !!!!!
2x18 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 2x18 Quote  Post ReplyReply Direct Link To This Post Posted: 30 December 2012 at 2:35am
well got 2x18s in four cabs , 4 ohms a cab was running a 707 in each pair
i think its time to get something newer , one amp 2 ohms a channel ( i only use 4 cabs every now and then not very often )
just one amp
budget about 800 - 1000
i want a good damping factor , can be repaired local
just a old dj
Post Options Post Options   Thanks (0) Thanks(0)   Quote krazyneil Quote  Post ReplyReply Direct Link To This Post Posted: 30 December 2012 at 4:23pm
qsc rmx5050 does 2k a side @ 2ohms ,ususally around £600 s/h
infinate 8 if you can find one ,youd probably get a scufffy one for 1k
maybe qsc pl9/pl380 at very top end of your budget at a push
or matrix xp/xt5000 make sure its the 2 ohm stable version, these are rated at 2.5k per chennel at 2 ohms,
i have use the matrix on twin 18s on quite a few occaisons and was really impressed
s/h aroun £500/750 depending which one and age,maybe worth an pm to andy or matt and ask how much new
