Stage blinders |
OllieMan
Joined: 02 March 2006 Location: Midlands, UK. Status: Offline Points: 973 |
Topic: Stage blindersPosted: 08 May 2012 at 6:57pm |
Hi All!
I'm a lighting newbie, and currently have a real basic lighting rig consisting of Par cans. I want to add some audience blinders like these: http://www.thomann.de/gb/stairville_blinder_4lite_bundle.htm I'm a bit confused as to how these wire up in my system. I notice that the lamps included are 120v. Does this mean I need a transformer? Are these normally ran off a dimmer channel? As my current dimmer is running par 64's I'm assuming it is a 240v output per channel (i'm in the Uk) I've tried looking on the net, but have had trouble finding any info at all. Ta, Ollie. |
DOJO MEDIA.
PA HIRE/ RECORDING STUDIOS/ BACKLINE HIRE. |
norty303
Joined: 18 August 2004 Location: Eastbourne Status: Offline Points: 7474 |
Posted: 08 May 2012 at 6:59pm |
My laser stuff: http://www.facebook.com/SubsonicSystems
mk2_ginger_biscuit69
Joined: 03 November 2008 Location: Aberdeen Status: Offline Points: 5623 |
Posted: 08 May 2012 at 9:54pm |
the 120v lamps are run in series pairs to make 240v loads......
But there are better options out there as outlined in above link |
shagnasty
Joined: 30 July 2007 Location: Guildford, UK Status: Offline Points: 4414 |
Posted: 09 May 2012 at 1:05am |
What you have found is DWE loaded half Mole, these will trash anything other than a AvoLites FD or better 10A dimmer Channel if you are not careful.
The 120V DWE lamps run series/Parallel to give you a 2.6Kw 240V load. They are great but do draw a lot of juice and are a bit OTT for smaller gigs, a better option ( the LED stuff isn't vaguely there yet for this application) maybe a pair or the 4 lite half moles you found, series wired with 28V Par36 250W ACLs, you end up with a 1Kw 120V lod per 4lite which you can either D-Load against a Par64 120V lamp or series against each other for a 2Kw 240V Load.
If you D-Load you can run a L<>R chase which looks cool but you need 2 dimmer channels or just series for a 2Kw blast.
ACL loaded moles look amazing and in smaller gigs may actually have more punch than the very wide DWE variant.
Plaguesguitarist
Joined: 30 April 2009 Location: Lincoln, Earth Status: Offline Points: 1800 |
Posted: 10 May 2012 at 1:53pm |
If you've already got par cans they can be as effective. We've used racks of par 56 cans with no gels on as blinders in smaller venues- quite effective...
We've got some proper stairville blinders but as Shagnasty says the power requirements limit the use. Par56 cans with a 300w bulb will use a lot less power and can be arranged foursquare as well ![]() Edited by Plaguesguitarist - 10 May 2012 at 1:54pm |
To steal MY sharpie. |
Tweet
