staiper micro scoop on winisd/hornrsp |
hmaudio
Old Croc Joined: 03 April 2009 Location: Nottingham Status: Offline Points: 3844 |
Posted: 16 May 2011 at 9:55pm |
just spent an hour trying to work both out and all im getting is the same graph on 2 drivers so i think im doing something wrong. any chance someone could sim these 2 drivers in the cab?
Stipe microscoop ES-15-BLH input. s1=620.5 s2=801 con=70 s3=1100 con=45 s4=1776.6 con=44 s5=4309 con=30.5 fr=0 tal=0 atc=2732.5 vtc=35664 driver one. pd158 inputs fs. 39.850 re. 5.895 qts. 0.205 qms. 6.935 qes.0.215 vas. 161.940 mms. 107.905 sd. 881.141 cms. 148.500 bl. 27.350 xmax. 6mm vd. 0.529 re. 4.59 driver two, b&c pz40 fs. 39 re. 5.4 qes. 0.27 qms. 7.6 qts. 0.26 vas. 137 sd. 855 xmax. 8mm mms. 24.5 le. 2 any help is much appreciated thanks Adam |
JR.junior
Old Croc Joined: 14 December 2009 Location: Slovenija Status: Offline Points: 1789 |
Thanks(1)
Hello Adam. Here you go!
PD grey, B&C black
hmaudio
thanks for that jr not sure what i was doing wrong.
This account is used by 2 people. |
JR.junior
Thanks(1)
Plots in 0,5Pi = group of 4 scoops.
PD156 at full power (650Watt). Max excursion reached at 30Hz.
Edited by JR.junior - 14 July 2011 at 8:34pm |
hmaudio
Massive thanks to JR for all his work!! just need to the graph of the 158 in a group of four and i can order the drivers! so far it looks like the 156 is the best driver for this cabinet?
cheers Adam
JR.junior
Thanks(1)
PD 158 at full power (600Watt). Max excursion reached at 21Hz.
PD 154 at full power (500Watt). Max excursion reached at 20Hz.
hmaudio
Thankyou for that jr!!
