  New Posts New Posts RSS Feed - Staiper Mini Scooper 18v2
 Post Reply Post Reply Page  <12345 6>
SN_sound01 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SN_sound01 Quote  Post ReplyReply Direct Link To This Post Posted: 21 April 2010 at 4:51am
Hi all This plan is it good for rcf l18s800 Thank you
levyte357 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357 Quote  Post ReplyReply Direct Link To This Post Posted: 21 April 2010 at 8:23am
I think the Xmax on the L18S800 is too low to get decent SPL out of this cab.
Fane 18-1000 would be better, and probably obtainable where you are.
Tekasis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tekasis Quote  Post ReplyReply Direct Link To This Post Posted: 11 September 2010 at 4:55pm
Originally posted by heinrich heinrich wrote:
Smile ahm...........staipe.....
if i had a P.audio driver...........let's say SD18 1000el......were should I put tis one on?
the MK2 or the MK3?
and also please . postan hornresp graphs with your said drivers if u may........thank you
Originally posted by The Builder The Builder wrote:
From experience with the Mk1, big boy drivers should be OK in Mk2. Double front baffle to be included. Do some bracing from front to rear baffle to take up a little chamber space.
Anyone built & tried out one of these MS-18 MkII's or III's yet ? Also where's the link or plans for the MkI's ?
**Heavy Weight-Line**
mykey- View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mykey- Quote  Post ReplyReply Direct Link To This Post Posted: 11 September 2010 at 10:25pm
you already have the best on the planet tek, ya mate shortmans mini scoop
what you trying to do, confuse us
tweeter box View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tweeter box Quote  Post ReplyReply Direct Link To This Post Posted: 13 September 2010 at 9:59am
I got Rhinos now Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote mykey- Quote  Post ReplyReply Direct Link To This Post Posted: 13 September 2010 at 12:21pm
did you buy them from lev?
Post Options Post Options   Thanks (0) Thanks(0)   Quote tweeter box Quote  Post ReplyReply Direct Link To This Post Posted: 13 September 2010 at 1:37pm
nope!
Post Options Post Options   Thanks (0) Thanks(0)   Quote tweeter box Quote  Post ReplyReply Direct Link To This Post Posted: 13 September 2010 at 1:38pm
theyre the MK3 plans, look good aswell, will give em a blast against the MK2 & MK3 Shortman Minis
t.geessounds View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote t.geessounds Quote  Post ReplyReply Direct Link To This Post Posted: 13 September 2010 at 6:21pm
i dont think i ever see builting pic of these have any built any of them yet???
staiper View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote staiper Quote  Post ReplyReply Direct Link To This Post Posted: 14 September 2010 at 1:16pm
no no no NO...!  Staiper's minis are The Best ones !
simple , serious, nice ... easy to build, deep , loud ..etc.
And ofcourse I can confirm that with mandatory scoopy smiley;  Wink  aaaAA HA!
..Oh damnnnn.. I forgot to create and log-in from new account but now is too late ...ehhhh Embarrassed
Just do it! ..or do not.. ;)
Drimacoustic View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Drimacoustic Quote  Post ReplyReply Direct Link To This Post Posted: 24 March 2011 at 12:12pm
What do you guys think about building MS-18 from 15mm material? Obviously more bracing will be needed, but overall, some weight could be saved. And if neo driver is used, it could be ultra light box :)
love begins below 40Hz
djeddie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote djeddie Quote  Post ReplyReply Direct Link To This Post Posted: 24 March 2011 at 1:24pm
The gain you make in using 15mm will be lost with all the extra bracing you'll need, if you ask me.
