Staiper Mini Scooper 18v2 |
Post Reply | Page <1 3456> |
t.geessounds
Young Croc Joined: 10 May 2010 Location: US... New york Status: Offline Points: 908 |
lol yes their is got to hit him up :)
tv00
Old Croc Joined: 10 August 2009 Location: Denmark Status: Offline Points: 1886 |
Hello all! I have 4 pcs pd.2150 sitting on the shelf shaking nothing...
So I think a miniscoop for a 21" driver is a good choice to get the lowest note without getting even bigger than a regular full scoop. Upscaling is extremely simple: multiply by 21/18 & use 21mm ply instead of 18mm So question is: -Which is the best (LOL) -Did anyone try a 21" version? (pergaps even with the weightless 2150:-) -Which of the following design that plans are available for would you prefer: -ms-18 mkIII (I'm not fond of the wasted space behind driver, but it's only little) -Heathrow b line mini -Hugo mini scoop -Mykey mini -MS-46 Plans for all except ms-46 here: http://blog-oong.blogspot.dk/2015/10/sub-woofer-scoop.html ms-46 is on fsp. Any hornresp inputs available for any of the above cabs? I guess that a mini that does well with 18" will also do well with 21" Kick will kick in at 60-70hz:-) |
msoundsystem
Young Croc Joined: 10 November 2011 Location: wales Status: Offline Points: 625 |
What's the better bin out of the 3 for the pd1850.? Mk1, mk2 or mk3
tv00
Yeah, that's the question, sold my 21"s, got a bunch of other cabs instead now, invaders tsw 721s, mach ms118s (1850 cabs)
Building from scratch takes time, finding someone that can actually program cnc takes even longer! I found 3 persons so far the last few years, claiming to be able to do it, nothing happened yet, probably I'm better of trying southwest cnc or starting the tablesaw:-) |
Teunos
If you have the drawings of the cab programming a cnc is easy peasy.
Especially if you have the dxf file or something like that it only takes ten minutes and the router can start to do its thing. Nulling the cnc every time with tool changes and loading the material is the time consuming part. |
Best regards,
Teun. |
Diaz
Registered User Joined: 09 November 2011 Location: SBG | Austria Status: Offline Points: 36 |
Just to be sure. Oberton 18 NXB1600 fitting MS18-MKII, please confirm:
http://www.oberton.com/en/products/neodymium-loudspeakers/367-18nxb1600.html Edited by Diaz - 06 January 2017 at 1:01pm |
SUBSISTENCE Soundsystem https://t.me/subsistencesoundsystem
Mini Scoop Soundsystems Group: https://www.facebook.com/groups/749452582177469/ |
tv00
Do a sim :-)
tv00
NBX-1601 is called "for horn application", higher BL & EBP, a bit lighter cone also.
But I'd still do a sim and compare to a driver that people like in there:-) Edited by tv00 - 06 January 2017 at 2:22pm |
levyte357-
I could draw up plan for 21" Mini Scoop, but it wouldn't be for free.. Or for sale.
I'd be more likely, to draw up plan, get it built, let prospective buyers hear cab playing, order some. |
Diaz
tv00
I have vey good experiences with hornresp & real life I must say, with exception from a rcf loaded tapped horn, there seems to be some standing waves and the vents on the back of the magnet are doing noise, no reason for blaming hornresp for not taking this into acount.
If you have it already see if you can find a similar cab for a test. Otherwise I'd recommend the 1601 driver as it is designed for horn more than 1600 |
Aman Gebru
Registered User Joined: 01 February 2014 Location: Delhi Status: Offline Points: 350 |
Yeah they always seem to be standing back. I wave on occasion, but they always seem to have a rear vent that brings something back. Edited by Aman Gebru - 08 January 2017 at 2:09am |
