  New Posts New Posts RSS Feed - Stasys 3 MK2 VS Porn Horn V2 vs Limmer 042
Father-Francis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Father-Francis Quote  Post ReplyReply Direct Link To This Post Topic: Stasys 3 MK2 VS Porn Horn V2 vs Limmer 042
    Posted: 20 September 2008 at 12:17am
Dom you built the Limmer042 with the porn 12", haven´t you .
how´s the sound comp´´ed to the porn or the stasys 3 series 2 what do
think if one built the 12" alone an the limmer on it´s own?
Music is the strongest form of magic.(+45 31879997)blakmanpro@gmail.com
bitzo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bitzo Quote  Post ReplyReply Direct Link To This Post Posted: 20 September 2008 at 8:21pm
could I suggest antoher contender? Omintop 15 or 12 as you like
norty303 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norty303 Quote  Post ReplyReply Direct Link To This Post Posted: 22 September 2008 at 9:04pm
Shouldn't make any difference to the sound if you built the 12" and 042 in separate boxes.
sKs01 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sKs01 Quote  Post ReplyReply Direct Link To This Post Posted: 22 September 2008 at 9:41pm
or perhaps modified mt121 (what ill be building pase plugged 6.5 and 12" section both or just the 6" plugged not sure yet still in very early stages working with what studio 45's got as a basis) thinking perhaps 1" or a convex melded pezio array (which is what ill be testing soonish as its got a minimal outlay to test it)
Edited by sKs01 - 22 September 2008 at 9:43pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Father-Francis Quote  Post ReplyReply Direct Link To This Post Posted: 28 September 2008 at 1:17pm
started cutting some form out to mold the horns an plugs
Dom View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dom Quote  Post ReplyReply Direct Link To This Post Posted: 28 September 2008 at 6:24pm
To be honest the 12" alone isn't doing anything too special as it's only playing 140hz-600hz.  You could probably get very similar results with an MT121.
The limmer 042 does a really good job of 600hz though...  Before I went down the limmer route I did try the mk1 porn horn top and an unreleased porn horn 6.5".  I preferred the limmer to be honest...
As for comparison with a stasys 3 mk 2 - they are a completely different beast.  The limmer has a much wider dispersion and is really designed for one box per side.  The stasys 3's are very good sounding boxes...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Father-Francis Quote  Post ReplyReply Direct Link To This Post Posted: 29 September 2008 at 7:22pm
hey Dom how did your boxes sound when didn´t you once build some porn-limmer mix do think they come close to the big boys F1´s or the stasys
Dom View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dom Quote  Post ReplyReply Direct Link To This Post Posted: 01 October 2008 at 1:20pm
The limmer porn boxes sound really good.
Not sure what you mean by come close to the big boys.  They do a different job.  They sound good but are really only suitable for small rooms due to the wide dispersion.
mykey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mykey Quote  Post ReplyReply Direct Link To This Post Posted: 01 October 2008 at 1:32pm
a 15 and my 2 x 8''
2 x 1'' in the center of the 2 x 8''
Deadbeat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Deadbeat Quote  Post ReplyReply Direct Link To This Post Posted: 01 October 2008 at 1:42pm
Can't see anything Mykey...
Away on extended leave.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mykey Quote  Post ReplyReply Direct Link To This Post Posted: 01 October 2008 at 2:16pm
sorry about the center drawing but you get the picture
Edited by mykey - 01 October 2008 at 2:23pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Deadbeat Quote  Post ReplyReply Direct Link To This Post Posted: 01 October 2008 at 2:28pm
Okay. Didn't realize. Looks cool. Have you thought of intergating that into a single piece (seperating the 8s and putting 2 splayed 1s in between one one big fibreglass baffle)?
