  New Posts New Posts RSS Feed - Stasys-X + Impulse 3tDelay Time
Noize-Guerilla View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Noize-Guerilla Quote  Post ReplyReply Direct Link To This Post Topic: Stasys-X + Impulse 3tDelay Time
    Posted: 21 February 2012 at 11:14pm
Hi guys,
hopefully one of you stasys-x owners can help me.
I tried to contact void but they seem to be very busy, on top of the X sits an Impulse 3t.
I have the delay for the Impulse 3t but no delay time for the Stasys-X (what i mean how much delay do I have to add to the Impulse 3t (Mhf + Lf) to get the LF of the Impulse to couple with the Stasys.
Any help appreciated!
I'm not poor, but money doesn't make me rich.
Post Options Post Options   Thanks (0) Thanks(0)   Quote toastyghost Quote  Post ReplyReply Direct Link To This Post Posted: 21 February 2012 at 11:42pm
1.6m
Grubbah View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Grubbah Quote  Post ReplyReply Direct Link To This Post Posted: 22 February 2012 at 1:25am
4.6 milliseconds roughly then?
spiffing View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote spiffing Quote  Post ReplyReply Direct Link To This Post Posted: 22 February 2012 at 9:41am
so is the stasys x horn length 1.6 meters?
will_i_am View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote will_i_am Quote  Post ReplyReply Direct Link To This Post Posted: 22 February 2012 at 10:29am
yes;;   1.6/340=0.0047
Post Options Post Options   Thanks (0) Thanks(0)   Quote will_i_am Quote  Post ReplyReply Direct Link To This Post Posted: 22 February 2012 at 10:32am
the speed of sound varies with temperature by around 0.4m per degree, increase in temp increase in speed. probably makes little difference unless you live in the gobi dessert though!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Noize-Guerilla Quote  Post ReplyReply Direct Link To This Post Posted: 22 February 2012 at 11:27am
Many thanks,
It worked out good on the first gig without adding the stasys delay, but I want it set up as it's ment to be.
Greetings
Forum Software by Web Wiz Forums® version 10.11
This page was generated in 0.140 seconds.
