Subs/kicks for Smt212's |
Post Reply | Page 12> |
Author | |||
unclejam
Young Croc Joined: 14 January 2006 Location: United States Status: Offline Points: 525 |
Posted: 05 June 2017 at 4:13am |
Hello, I have 4 Smt-212's that need some support in low end department.
My initial plan was to have a pair of Cubo kicks and 4-6 cubo subs a side but everytime I mention the word Cubo I get a healthy dose of side eye. I am now considering some Tham 15/18's or maybe some hog scoops. The intended use is for live music/dj use for indoor and outdoor use. Genres from Psychedelic rock from the 60's and 70's to to reggae, house, trance, soul rnb the works really. Any help would be widely appreciated. Thanks Gents! |
unclejam
Also Considering the Th-18 from xoc-1
Keen
Young Croc Joined: 30 May 2011 Location: Brisbane, Aus Status: Offline Points: 1203 |
How low can you take the SMT's Uncle?
unclejam
They are good till 90 but don't get that good horn-loading going till 140-160.
Risc_Terilia
Young Croc Joined: 15 December 2007 Status: Offline Points: 699 |
Couple of band pass horns per side?
mobiele eenheid
Old Croc Joined: 15 August 2004 Location: Netherlands Status: Offline Points: 1568 |
I'm gonna cry in a corner now! |
Mikkel
Young Croc Joined: 17 May 2013 Location: Huddersfield Status: Offline Points: 549 |
Big pile of gsubs? 3 a side would be good height wise, but obviously need a few decent amp channels to power them. Nice and easy!
Teunos
You do that. At the end of the day, like any bandpass cabinet, the Cubo and assorted cabinets are resonant devices with very high Q. Frequency response never tells a complete picture. Taking a look at the group delay and impulse response of a cabinet such as a Cubo will tell you why most people who have heard them give you
If you will only be playing EDM and assorted styles you will probably get away with it, simply because no one can tell the difference not knowing what the record should really sound like. Run any low mids from vocals through it and you will be like; what the flying f***.... If there is any advice i can give you, after building several of these (i.m.o.) shitty resonant devices, is just don't do it. The added efficiency with relatively small cabinet volume just is not worth it. Either go fully horn loaded, or just stick to BR. Tapped Horns in my book are the best compromise between both worlds, cubos are not. I have mentioned this time and time again on here, but the day i decided to build BPH over pure FLH for the kick section of my system was a pretty black day in my history book. Now that i dont use the system as much as before i really cannot be bothered to build FLHs instead.
Edited by Teunos - 05 June 2017 at 10:23am |
Best regards,
Teun. |
Mikkel
Bit harsh...
Each to their own i would say. Vocals running through proper sub 18's sounds shit anyway you cut it. Id say the cubo with its low highpass avoids this (and sounds quite good with kickdrum and bass guitar in my opinion) if cut to a nice double 12 or whatever. I agree with you about short bph's in the low mid area for live music. Anyway theres no need to bash a mans design purely cos you got your knickers in a twist about bph's. The cubo has a place and lots of people use them happily, me included. |
bass*en*mass
3x 218s or three of Djks ppsl215 should be an easy build, suitable budget drivers are available in US, reflex might be the most universal Subs to match your application/musical diversity?
3x 18" THs should suit aswell but are complicated to build and more expensive to load? |
unclejam
Well considering I've allotted roughly $300 per driver for the build the Th18's would be the least expensive and be easier on the amps considering my driver of choice for my 3 options that I mentioned would be the 18 Sound 18LW2400. Also Teunos, I wouldn't be running the Cubos subs past 80 hz Considering that I mentioned the cubo kicks to go on top of said cubo subs so there wouldnt be any vocals going through the subs in that pass band anyway in addition to the fact that I almost always run auxed subs for cleaner mixes. With that being said I am currently leaning towards the TH18's due to truck packing and bang per box/buck and what I've read on them. |
bass*en*mass
not sure the 18lw2400 cone will cope well with the TH compression ratios tbh., its a great reflex driver though.. you might want to doublecheck if its really suitable?
Obviously that depends on amps aswell, an amp capable of powering 3 a side might be quite expensive, might be better to get smaller amps with enough stable output at 4ohm and get 4ohm drivers instead? (or build double 8 ohm cabs) - would be much more flexible aswell re application/split rig etc.? 2way bass section is much harder to get right and requires proper measuring/setup, hence i would not really recommend it, specially not with your mainly non dance music styles mentioned.. the 212s, depending on driver, should meet a 218/215/TH easily at around 100hz.. |
