  New Posts New Posts RSS Feed - subs to add to turbo
abrupt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote abrupt Quote  Post ReplyReply Direct Link To This Post Topic: subs to add to turbo
    Posted: 18 May 2017 at 6:32pm
i want to add more bottom end to my system (30hz) without getting more turbosound,has anyone got any suggestions as to what would be good to combine to my current setup
8 tse 118
4 tms 4
shagnasty View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shagnasty Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2017 at 7:20pm
TSW-718 plans are floating about 4 of those run 30-80Hz would work well sonically and stack easy,
cravings View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cravings Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2017 at 7:25pm
or just buy 4.. from me.. or someone of your choosing..
or buy the 4 tsw718 AND a pair of TSE218 from me...
Edited by cravings - 18 May 2017 at 7:26pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote abrupt Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2017 at 8:07pm
pm me what you have a prices please
mi mong View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mi mong Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2017 at 7:19am
tsw 718 is a 50hz up cab... specs say minus 3db at 50 hz  I would go for some thing else if you want 30hz
i went out today in my dressing gown......
Post Options Post Options   Thanks (0) Thanks(0)   Quote shagnasty Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2017 at 8:48am
Having used 2 of these boxes under TMS-4s, as apposed to reading the manual, they will produce viable energy @ 30Hz with the crossover points suggested, they bleed off like hell when run out to 180Hz to meet floodlight but the 4xLS1802 in the Kik section that will not be an issue.
Post Options Post Options   Thanks (0) Thanks(0)   Quote cravings Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2017 at 9:20am
Post Options Post Options   Thanks (0) Thanks(0)   Quote shagnasty Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2017 at 9:29am
That's the way to run Floodlight!!!!! 5Way-tastic!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote abrupt Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2017 at 2:58pm
i had the system out last night...8 tse 118 4 tms 4 and it sounded beautiful.so clear and punchy.but i will say for that amount a heavy sub section is needed
Post Options Post Options   Thanks (0) Thanks(0)   Quote shagnasty Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2017 at 6:46pm
Heavy but not slow/slurpy/muddy, the TSE- 18" defined decent low end, to sit on some 1850 based slow horn or bonking reflex box would be a shame....Smile
4D View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 4D Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2017 at 6:56pm
can you not run that with the18" in the 118's doing 30hz-70hz and then the 18"s in the tms4s 70hz to 250hz should sound lovely
Post Options Post Options   Thanks (0) Thanks(0)   Quote shagnasty Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2017 at 7:19pm
The truth is you can split the bands but the TSE/TMS is 300W 18" with a 3" VC, I've used TSE-218s in 30>110 and TMS 80>250 with good results, bit a TSE-218 is like 2.5 TSE-118s (the better mouth coupling make a big difference) and to get "low" you need 6 TSE-218s aside, which IMHO won't sound as solid as 2x718 with the more powerful drivers.
This is what i run for Live stuff :-
But for Dance gigs I put the 118s on there side and stick another 718 under them (or a couple of 121s and run 5way), the 118s I have aren't strictly 718s (Apart from obviously having a driver missing) they use Fane Neo drivers, are made from 15mm not 18mm and are slightly re-tuned to not drop a lo but run faster...
The other thing 718s give is a MUCH better stack height...
