Suggested 1" Comp's for use 5khz-18khz |
Post Reply | Page <12345> |
Author | |||
levyte357-
http://www.lean-business.co.uk/eshop/bms-4505nd-5-neodymium-planar-wave-driver-175-vc-80-w-aes-113-db-8-ohm-p-2639.html?zenid=6323d142ede68b06901f417d39ce48a0 £213 GBP each, soon stacks up, if 2x driver per mid cab, 4x mid cabs. |
snowflake
no, beause the synergy horns are a conical horn there is far less throat distortion because of the higher flare rate. with an exponential horn the air starts distorting because of adiabatic compression. |
_Natty_
Young Croc Joined: 01 April 2007 Status: Offline Points: 663 |
my vote is for the mighty b&c de250
Earplug
Just buy some JBL VRX - 3 x 1" drivers.
MattStolton
Ouch! Last term I heard a VRX rig, it sounded a little "shrill" to say the very least!
bob4
guys, I didn't ask for a "line array wave guide" specifically. |
Earplug
Like a lot of JBL stuff, very top heavy, but some people seem to like that. I did a gig a while ago where the group brought a couple of VRX 932LAP´s and asked me to wire them in as side fills! Talk about shrill. I suppose they'd never heard about in-ears. |
toastyghost
You seem to have mis spelled "complete and uttter dog shite" there Matt |
nickyburnell
These (cp380) can be found lurking in Mach 1x15 cabs. The MDF ones with the silly rear protruding handles that snap off. eBay bargains sometimes |
levyte357-
Beyma actually have some 1.4" drivers, that according to response graphs, have better 12-18k, than the CP380. |
MarjanM
Top end is very dependent on the horn used.
Wider the horn dispersion, better the top end. No throw dough. CD horns also suffers at the very top end, but provide most even dispersion. Tractrix horns offers best on axis top end, but not to the rest of dispersion pattern. You need to stop looking at specification graphs, unless you plan on using the same horn measurements were made with.
levyte357-
There is much to gain, from using same horn, measurements made with.. There are few exceptions, like B&C ME60, which sounds immaculate with Beyma 2" drivers. |
