  New Posts New Posts RSS Feed - Super Bass Horn V.02 by Startec (Quad Acoustics-F)
 Post Reply Post Reply Page  <1 3637383940 46>
trips View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote trips Quote  Post ReplyReply Direct Link To This Post Posted: 22 January 2017 at 12:45am
Hi guys ,, can anyone tell me if my sp1808 speaker will work in the sbh ?
Fs       37Hz
Re       5,2 Ohm
Le       1,34 mH
Qms   11,44
Qes     0,400
Qts      0,386
Xmax   8 mm
Xdam 40 mm p-p
Sd      1210 cm²
Vas    191 liter
Mms   199,20 g
Cms   0,093 mm/N
Rms   4,048 kg/s
BL      24,54 Tm
n°       2,325 %
SPL   2,83V @ 1m : 97,3 dB
Paes 800 W
Thanks !!
corell View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote corell Quote  Post ReplyReply Direct Link To This Post Posted: 22 January 2017 at 6:09am
No it wont, the motor is not strong enough in comparison to the mass of the cone (high qts value).
Post Options Post Options   Thanks (0) Thanks(0)   Quote trips Quote  Post ReplyReply Direct Link To This Post Posted: 22 January 2017 at 12:04pm
Oke thnx thats 2 bad
Phantom View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Phantom Quote  Post ReplyReply Direct Link To This Post Posted: 08 February 2017 at 4:02pm
Hello, does anyone know how low 2x SBH's go loaded with two pd 1850's? Thankss
JohnnyKarr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnnyKarr Quote  Post ReplyReply Direct Link To This Post Posted: 11 April 2017 at 4:36pm
Hey Bee. I finally got a couple built and I was curious if you could answer a question for me... Is there any merit to adding any dampening material if using RCF LF18n401 drivers? Thanks-
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnnyKarr Quote  Post ReplyReply Direct Link To This Post Posted: 13 April 2017 at 6:35pm
Hey everyone, there was some complications with the RCF drivers I was looking at picking up for my SBH builds. I was looking into an alternative driver and I was hoping someone may be able to tell me if these Faital 18HW1070 would work in these cabs... here are the parameters.
Fs 32 Hz
Re 5.4 Ohm
Qes 0.39
Qms 10.0
Qts 0.37
Vas 171.2 dm^3 (6.05 ft^3)
Sd 1124 cm^2 (174.22 in^2)
Xmax (4) 13.00 mm
Xdamage (5) 30 mm
Mms 259.0 g
Bl 27 N/A
Le 1.68 mH
Mmd 237.7 g
Cms 0.10 mm/N
Rms 5.2 Kg/s
Eta Zero 1.41 %
EBP 82 Hz
Thanks for any help, much appreciated.
patryk1305 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote patryk1305 Quote  Post ReplyReply Direct Link To This Post Posted: 13 April 2017 at 10:22pm
Fs 32 Hz
Re 5.4 Ohm
Qes 0.39
Qms 10.0
Qts 0.37
Xmax (4) 13.00 mm
Xdamage (5) 30 mm
Mms 259.0 g
Bl 27 N/A
Le 1.68 mH
Mmd 237.7 g
Cms 0.10 mm/N
Rms 5.2 Kg/s
Eta Zero 1.41 %
EBP 82 Hz
Not really suited for horn loading Dead
Post Options Post Options   Thanks (0) Thanks(0)   Quote toastyghost Quote  Post ReplyReply Direct Link To This Post Posted: 13 April 2017 at 10:31pm
If they'll fit and you want Faital the 18XL1600 is your shout for horn n
Strawberry Jam Sound View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Strawberry Jam Sound Quote  Post ReplyReply Direct Link To This Post Posted: 16 April 2017 at 12:39pm
Hi guys, We're about to build 4 of these horns and their debut will be at a festival. Its not a huge tent and due to the sizing of everything the guy wants us to run in stereo. I've read a lot about these boxes and how the coupling is quite important, how big an effect will splitting them into two stacks have? should we push to try and get it in a mono stack with the bins on their sides?
Theyre going to be loaded with v18s and run off an SAE with USBs and MT121s above them
Cheers for any tips.
I'll get posting some pics once we start the build in a couple of weeks!
Peedro View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peedro Quote  Post ReplyReply Direct Link To This Post Posted: 17 April 2017 at 7:15am
Don't worry. They will work fine in two stacks. Especially outside.
Post Options Post Options   Thanks (0) Thanks(0)   Quote toastyghost Quote  Post ReplyReply Direct Link To This Post Posted: 17 April 2017 at 10:43am
Well they will work but the mouth area will not be there to support the low corner cutoff - so you will need to watch for overheating coils, and be wary of the amount of power going in and spectral content of the music.
cassiya View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cassiya Quote  Post ReplyReply Direct Link To This Post Posted: 17 April 2017 at 11:00am
Don't worry mate. 2 per side is all you need
Just because you got more boxes that don't make you a man....
This page was generated in 0.108 seconds.
