  New Posts New Posts RSS Feed - Super Bass Horn V.02 by Startec (Quad Acoustics-F)
 Post Reply Post Reply Page  <1 373839
Strawberry Jam Sound View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Strawberry Jam Sound Quote  Post ReplyReply Direct Link To This Post Posted: 19 April 2017 at 6:15pm
That's good to hear thanks! The tent is quite small so we shouldn't have to run them too hard so hopefully heat wont be a problem. Ply arrives on Friday, can't wait to get started. Anyone got any building tips for these? We're not experts by any means but managed fine building mt121s, hoping these won't be too much more difficult. We planned to make a jig in order to rebate the sides using one of those bushing for a router and a template just to make sure everything slides into the right place. We thought to remove the back bottom corner too and make the 45 degree piece double thick to put wheels on so we can just tip it back onto the wheels :)
JohnnyKarr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnnyKarr Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2017 at 1:32am
Hey guys, wiring up my subs.... do i have to reverse wire it since its facing backwards? Ie. +1 on the input to -1 on the driver and -1 on input to +1 on driver? Thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Strawberry Jam Sound Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2017 at 3:12pm
The driver doesn't go in backwards, the cone faces the air through the horn if that makes sense, so you don't need to wire it backwards. You'll need to delay your other boxes appropriately to account for the 3m horn length
djeddie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote djeddie Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2017 at 4:44pm
Wire it as normal, (+ to +, etc) and use use your LMS to control the phase.
Chas n Dave : it's like Drum and Bass but with beards.
E=mc² ±3dB
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnnyKarr Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2017 at 6:17pm
Thanks everyone!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Strawberry Jam Sound Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2017 at 9:17am
What have people done in the way of cladding on the inside of the box?
Thanks
