  New Posts New Posts RSS Feed - Tested Matrix again...
 Post Reply Post Reply Page  123 10>
Pasi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pasi Quote  Post ReplyReply Direct Link To This Post Topic: Tested Matrix again...
    Posted: 15 February 2012 at 7:00pm
Had some fun today because Andy kindly sent me an amp to test and play around with it. I don't exactly now what power it has or details like that, other than mainly intended for the tops, not so much for the subs.
Comparison was mainly against LAB PLM10000Q... My not so great favorite anyway :)
On bass duty there wasn't anything new. Matrix stole the show completely with its ability to drive cones properly and keep them under control. Bass sounded much deeper and tighter than with LAB but not as good as some other larger Matrix amps i've heard.
Cabinet used was some reflex proto 218.
But in the mid high test... Stunning. Just stunning. Like night and day. Lab did sound ok, and like many typical modern D-class amps. Breathless, cold, lacked details, clarity and dynamics.
Matrix turned several heads with its warm, clear, well controlled and very dynamic sound. Like my missus said "LAB sounds like there is just few bits of the track and separate items playing, and all the wrong parts. Matrix sounds warm and the song plays like a full tracks with all powerful details."
I also played this amp to general manager and after 2 change overs he asked me to stop and said that left cabinet sounds better and wanted to know what was the difference. He was very surprised to hear that only difference was the amp, and which amps he was listening to :)
Cabinets used were OHM BR-15.
It just proves to me that modern audio industry isn't quality driven, it is money and brand driven.
JohnnyPyro View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnnyPyro Quote  Post ReplyReply Direct Link To This Post Posted: 15 February 2012 at 7:11pm
Nice write up Pasi ..
I'm looking fwd to A/B'ing a matrix amp against my MC2's , i used to use the old STR series to run mid tops .. the class A/B ones .. always sounded very HIFI,  at the time i had QSC's and Crest CA's and id say the CA and STR were about them same on output quality on Mid Tops and the QSC didnt come close , may favourite on bass was the CA, although i didnt have a matrix with the same output as my CA, so it may have just been the headroom that gave the CA the edge
infrasound View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote infrasound Quote  Post ReplyReply Direct Link To This Post Posted: 15 February 2012 at 7:15pm
Tested enough class D by now, from common as muck to exotic - and have only found one that sounds good to my ears (Nuforce Reference 9).
Always end up back at the AB monoblocks Thumbs Up
SYG Media View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SYG Media Quote  Post ReplyReply Direct Link To This Post Posted: 15 February 2012 at 7:24pm
we just did an a/b between our old lab fp6400's and the new matrix MF range. Matrix was so nice in depth and warmth. Can't knock the labs but i would have chosen the matrix, and saved money by doing so but not compromised on sound, improved it!
Video Production, Sound & Lighting Hire
SamV View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SamV Quote  Post ReplyReply Direct Link To This Post Posted: 15 February 2012 at 8:19pm
MF range?
t0m View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote t0m Quote  Post ReplyReply Direct Link To This Post Posted: 15 February 2012 at 8:25pm
MotherF*CKER!
http://www.microrave.biz
PA/Sound/Staging/Lighting & Laser Hire for London & the whole of the UK
[value=(probability of success x importance)÷effort]
Post Options Post Options   Thanks (0) Thanks(0)   Quote SYG Media Quote  Post ReplyReply Direct Link To This Post Posted: 15 February 2012 at 8:26pm
yep, motherf**ker is what it stands for. Just wait till you hear one mate! smiles all round.
Sinfinity View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sinfinity Quote  Post ReplyReply Direct Link To This Post Posted: 15 February 2012 at 9:52pm
MF = Mighty Fine ( or something similar Smile )
Matt at MatrixAmplification dot com
Heathrow_B_line View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Heathrow_B_line Quote  Post ReplyReply Direct Link To This Post Posted: 15 February 2012 at 10:00pm
words are ok but lets see some pictures/readings/waveforms
descriptions of trouser flapping or eye vibrating is good for the scoop boys or dnb mess heads but you are supposed to a professional
you must have access to the proper equipment
nice sound bite but i could say exactly the same thing about a berry ep2500
its all subjective without measurements
look at dj leco posts for a reference review
Post Options Post Options   Thanks (0) Thanks(0)   Quote infrasound Quote  Post ReplyReply Direct Link To This Post Posted: 15 February 2012 at 10:09pm
He gave his respected opinion on sound quality. Go stick an oscilloscope on the outputs if you want to know how it functions as an arc-welder!
And you would be lying if you said the ep2500 was hifi Wink
SamV View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SamV Quote  Post ReplyReply Direct Link To This Post Posted: 15 February 2012 at 10:29pm
Maybe it is to him :p
Pasi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pasi Quote  Post ReplyReply Direct Link To This Post Posted: 15 February 2012 at 10:59pm
Pics don't tell how it sounds, and all this was about how it sounds. That's the only thing what really counts at the end of the day. If the claim is that Matrix MF or Baby MF in this case sounds better than LAB, only way to find it out is listen.
Someone else can do the geek part, i'm not the guy to do that sort of measurements.
Forum Software by Web Wiz Forums® version 10.11
