  New Posts New Posts RSS Feed - TH-18 build
TH-18 build
tv00 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tv00 Quote  Post ReplyReply Direct Link To This Post Posted: 20 March 2017 at 6:58pm
Why not build V2 that drops a bit lower and doesn't have the wasted space inside?
smitske96 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote smitske96 Quote  Post ReplyReply Direct Link To This Post Posted: 20 March 2017 at 9:21pm
To be honest I actually didn't see the v2 version..
Although the triangle makes the m20 really solid (al is it a bit overkill).
The testcabinet for the mid/highs is planned next week. I am going to try the 12nw76, if it won't do the job I will look further for something else.
tv00 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tv00 Quote  Post ReplyReply Direct Link To This Post Posted: 21 March 2017 at 10:45am
Uh, keep reading the x0c1 TH-18 thread , after the cone correction they end up by extending the horn to make the second bend close enough to the cone to become the cone correction, then they move the triangle also and add a bit of extension this way also.
Same has been made for Jbell SS15 (also a later mod I believe)
Then it all comes very close to Danleys subs
Post Options Post Options   Thanks (0) Thanks(0)   Quote smitske96 Quote  Post ReplyReply Direct Link To This Post Posted: 22 March 2017 at 8:18pm
I'm looking forward to do some measurements!
I've got a calibrated Behringer ECM8000 as a mic.
This page was generated in 0.055 seconds.
