  New Posts New Posts RSS Feed - THAM 12 - a compact 12" TH
 Post Reply Post Reply Page  <1 89101112 13>
all bass View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote all bass Quote  Post ReplyReply Direct Link To This Post Posted: 21 April 2015 at 11:19pm
Just stick to the recommended driver.
If you are looking for alternatives, then take a good look at all the parameters and make sure that they are very very close to the recommended one.
panos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote panos Quote  Post ReplyReply Direct Link To This Post Posted: 29 April 2015 at 9:17pm
ok....
so i'm looking for a driver with quit high xmax...
i made a simulation with gbl gti1200 with horn resp and i have a question...
the graph i see at <<acoustical power>> is the subwoofer's senseativity with 1watt at one meter with the jbl1200gti driver?
Edited by panos - 29 April 2015 at 9:40pm
lost eden View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lost eden Quote  Post ReplyReply Direct Link To This Post Posted: 29 April 2015 at 10:11pm
The GTI 1200 is not a good match for the THAM. It has a fairly small xmax, the BL is too low & the QTS is too high.
T-Bone View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote T-Bone Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2015 at 12:02am
Will the Eminence Kappalite 3012LF work good in this cab? Thanks
BASS, how low can you go!
Sapro2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sapro2 Quote  Post ReplyReply Direct Link To This Post Posted: 01 December 2015 at 12:04pm
Sorry to post another 'will xxx worki in the Tham?' question but..........
Would a Lab12 work in the Tham12? It seems to have a few of the TS requirements?
Splat Soundsystem
Baby Sham pram Soundsystem
Sapro - SoundCloud
https://soundcloud.com/sapro
DJ Sapro. West country free party DJ and Producer.
tv00 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tv00 Quote  Post ReplyReply Direct Link To This Post Posted: 01 December 2015 at 5:07pm
Do a simulation in hornresp!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sapro2 Quote  Post ReplyReply Direct Link To This Post Posted: 01 December 2015 at 6:29pm
Ok, not used hornresp before. Where is the best place to find a dummies giude?
Thanks
Splat Soundsystem
Sapro - SoundCloud
tv00 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tv00 Quote  Post ReplyReply Direct Link To This Post Posted: 01 December 2015 at 8:17pm
I use the help file, I think it's great:-)
But Google it & it:-) See:
http://www.hometheatershack.com/forums/diy-subwoofers-general-discussion/36532-hornresp-dum-hmm-everyone.html
https://www.freespeakerplans.com/forum/8-advanced-discussion/8687-horn-resp-for-beginners?start=10
http://www.avsforum.com/forum/155-diy-speakers-subs/1212465-simple-tapped-horn-tutorial-using-hornresp.html
Ok basically first section is 2 pi (free on ground) 2,83V (1watt) (or use 1 pi to compare to 1pi sims)
Next section is how area increases by hornsectionlength, copy-paste that from tham12 simulation.
Next section is speaker specs, read specsheet, fill out what you can first, double-click other fields to make hornresp calculate for you, then it will ask for Fs, Qes etc.
Last section is rear/front chamber, copy past from tham12-in this case all zero I guess.
Edited by tv00 - 01 December 2015 at 8:21pm
mini-mad View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mini-mad Quote  Post ReplyReply Direct Link To This Post Posted: 01 December 2015 at 9:25pm
I think Anders said it was a no go....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sapro2 Quote  Post ReplyReply Direct Link To This Post Posted: 02 December 2015 at 8:30am
Ok, thanks guys. I will have a play with hornresp though
Splat Soundsystem
Sapro - SoundCloud
Chendy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chendy Quote  Post ReplyReply Direct Link To This Post Posted: 02 October 2016 at 5:40pm
Which driver has the best performance?
Im looking http://www.martinsson.cc/blog/index.php?entry=THAM12 - here at the list of simulated drivers, but can anybody recommend any which might have the best performance (ignoring efficiency). Want max SPL, with good frequency response, quality etc etc. I have access to large amps, so which driver will allow me to squeeze as much as possible out of these little subs
thanks
tv00 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tv00 Quote  Post ReplyReply Direct Link To This Post Posted: 04 October 2016 at 10:50am
Fane 12xb has great perfomance in there, why would you "ignore efficiency"
If you want to play loud it's all about efficiency.
Raw power by WATTS will distort & blow your speaker at the end of the day
What is a no-go? Using different drivers?
Don't know what the new-christian drivers puritanism in here is aboutClap
-But I know he suggested several drivers and are open to this.
Yet you might refer to something copletely different?
