"The" Amplifier Internals thread ... |
Post Reply | Page <1 9091929394 130> |
Oldmaelstrom
Registered User Joined: 07 October 2009 Status: Offline Points: 15 |
Posted: 18 March 2010 at 3:51pm |
subbass
Old Croc Joined: 30 March 2009 Location: bristol Status: Offline Points: 1683 |
Posted: 25 March 2010 at 12:47am |
Samson servo 201a
Oldmaelstrom
Posted: 25 March 2010 at 8:23pm |
Symzzi
Registered User Joined: 23 May 2006 Location: United Kingdom Status: Offline Points: 245 |
Posted: 25 March 2010 at 9:16pm |
QSC MX 3000a
Oldmaelstrom
Posted: 27 March 2010 at 8:04am |
Dynacord LX2200 (Electrovoice CP3000)
BlueDragon
Registered User Joined: 02 March 2010 Status: Offline Points: 360 |
Posted: 28 March 2010 at 7:22am |
Cerwin Vega CV-900
I know it's hardly a particularly powerful amp (210Wpc @ 8r) and CV don't have a particularly good reputation for their amps, but I was still surprised at how little was inside. (The 2 caps are both 10,000uF if you're interested)
Cheers
backlash
Old Croc Joined: 11 November 2008 Location: Devon Status: Offline Points: 3532 |
Posted: 28 March 2010 at 7:31am |
Little isn't always better... I think a lot of cerwin amps are disco branded amps really. Never really fussed me unlike the smalled Tamps rated similar sized to this amp. My old Tamp 700 model had more in it than the cerwin, transformer was a little bigger and it did 260@ 8ohms p channel. |
Saul
Old Croc Joined: 15 June 2007 Status: Offline Points: 5912 |
Posted: 28 March 2010 at 12:04pm |
that samson servo is a bit of a mess!
SimonHomkham
Registered User Joined: 19 August 2008 Location: Sweden Status: Offline Points: 23 |
Posted: 28 March 2010 at 12:17pm |
Dynamic Precision P400P
More pictures visit my homepage www.somsaks.com I have around 160 pictures from this amplifier |
More informations about me just go to my homepage at http://www.somsak.blog.com
Nitz V1505
Old Croc Joined: 16 September 2009 Location: UXBRIDGE Status: Offline Points: 1719 |
Posted: 28 March 2010 at 8:29pm |
Them amps look wicked mate!!!! Love the fat transformer and caps.proper job.
& THE TOPS LIKE LIGHTNING..... |
Pirlo
Registered User Joined: 25 February 2010 Location: Germany Status: Offline Points: 244 |
Posted: 31 March 2010 at 5:32pm |
Spring-clean and foto-time
Ma-1200, hope not listed yet. |
DjLeco
Young Croc Joined: 21 April 2009 Location: Bucharest Status: Offline Points: 817 |
Posted: 01 April 2010 at 11:56pm |
Mine club amplifier, saturday it have sudden death... Working on 2,66 ohm/channel/mid-hi 110 Hz above. Died NTC thermistors 10 ohm from inrush current limmiter circuit.
But oficially, those must been shorted by blue relais after 2-3 seconds from startup, but relais doesnt receive 24 volts for coil... TO ALL OWNERS OF PROLINE 2700,PROLINE 3000, SI PHONIC, check and better , REPLACE, parralel diode on relais coil (D503 at Proline 2700 si 3000),Specially if is 1N4148 with 1N4007. Also replace the transistor wich commands the 24Vdc for relais coil (TR503 at Proline 2700 si 3000), officialy is C2240 (2SC2240) with BD139 or better, BD237. As ideea, the ones wich have Proline 2700, or Proline 3000 amps, and found those NTC thermistors burned, the relais doesn't work well.
Amp 1: Burned PCB: Output devices, originals ON Semiconductor: Final stage Ch1: Trafo: NTC: NTC differency with the ones that I put there: NTC changed: Secondary Cu-Em, just 1,5mm diameter, TOO TINY!! Soft start: Here is where must be changed those transistors and diode!
[size=16]Small movies: Inrush current limmiter now working!: Prezentare+1Ch @ 1000 Hz ,max 76,5 Vrms-4 ohm: Ch1+Ch2 @ 1000 Hz/4 ohm:
Ch1+Ch2 @ 100 Hz/4 ohm:
Ch1+Ch2 @ 30 Hz/4 ohm:
Ch1+Ch2 @ 5000 Hz/4 ohm:
Ch1+Ch2 @ 10000 Hz/4 ohm:
Ch1+Ch2 @ 20000 Hz/4 ohm:
Just Ch 1 @1000Hz and 100 Hz/2 ohm:
Just Ch 1 @30 Hz-2 ohm
Just Ch 1 @100 Hz/2 ohm supply voltage dropping:
Advantages and disadvantages:
Comments or questions,are welcomed!
