The difference between an Inuke and a Powersoft |
Post Reply | Page <1234 6> |
Darkstar
Registered User Joined: 08 October 2014 Location: Italy Status: Offline Points: 326 |
I suppose they do throw in better components than the standard Lab copies though, therefore increasing reliability.
Anyhow, I've seen a copy with a Lab Gruppen badge today. Quite a shame, can't even see the point of that either... |
Bass =/= Enough
kedwardsleisure
Old Croc Joined: 20 January 2009 Location: Staffordshire Status: Offline Points: 4936 |
RCF have always used OEMS for their PA amps.
North Staffordshire |
U.Viktor
Young Croc Joined: 04 May 2010 Status: Offline Points: 716 |
Some of the most important differences remain hidden until you do not use them in real world!
The INUKE completely drops power as soon as the AC drops just a little = useless in professional application The INUKE has NO real output feedback, the frequency plot depends on the load behavior = useless in professional application The INUKE has badly designed "cheap" power supply, creates harmonics and current spikes on the mains (huge problem if you have several of those..) = useless in professional application The cooling structure of the INUKE is not suitable to work in non-controlled "dirty " environment, without the risk of quick failure. I have been informed several even more damning technical details but most of you would likely not understand therefore I will not share those. The INUKE is NOT a professional amplifier but could be good for a cheap household amplifier. |
U.Viktor
Such load dependent frequency response of the INUKE could be very ugly on vocals, or anywhere in the upper range..
Also produces different sound character on each type of the speakers.. which is very difficult to handle. |
shagnasty
the SAE amps sound fine to my ears, better than a Lab on low end and despite claims they have appalling PFC I am not seeing any issues when I clipped mine intro a D-load for shits and giggles....
U.Viktor
Put 12 of them to a remote mains line and you will see the "problems" For example the airbags or ABS are totally useless parts of your car, until you do not need them.. Edited by U.Viktor - 08 September 2015 at 7:24pm |
shagnasty
The point is *I* won't, I'd use the proper gear to give me a stiff enough main, if you throw 12 10Kw power amps on a bit 25mm2 of course all hell will break loose... As for ABS, I have mine turned off, I can out-drive it and proved so many times on a skid pan....
Edited by shagnasty - 08 September 2015 at 7:41pm |
Darkstar
^ carplans.com
Bass =/= Enough
jammin75
Old Croc Joined: 08 July 2012 Location: west midlands Status: Offline Points: 2375 |
they better on bass duty but have their limits been usin my inuke6000dsp for quite a while now but my heavy weight has better tone and more spl |
jammin75
already said before they are harsh sounding on mids an tops |
shagnasty
TBH, back on topic, the Powersoft maybe better value than the iNuke, but when the iNuke is so much cheaper the comment of unfair comparison applies, you will never get a front wheel drive car to handle or go fast, but some people can't afford RWD.
I ran a club on EP2500s, a lot of them, they were replaced with SR 707s and may I say held their value very well, they cost £200+vat each and all sold for £130 plus, the SR were in different league sound wise but I bought the SR of JH as he shifted them out and the EP were probably better value than the SR stuff (707 was £1K in '94) the iNuke kit isn't going to head up against Powersoft/MC2/FFA maybe even SAE which is nearer it's price point, but for $500 it makes better frequency response, PFC, Power, SPL and bhp/tonne than $500 worth of the above!!!!! I deliberately left PKN out of that list as I haven't used one, I don't know of any Pro Audio companies that are using them and they have no UK demo stock, so to me I can't comment on a complete un-known.... |
Darkstar
PKN are somewhat closer to Powersoft and similar brands for the price though, aren't they?
Anyhow, Marjan uses these and they also have quite a good reputation here on the forums. Edited by Darkstar - 08 September 2015 at 9:15pm |
Bass =/= Enough
