THE NEW CELESTION CF18VJD TESTED TO THE MAX |
Post Reply | Page <1 5678> |
Author | |||
LIGWA
Young Croc Joined: 18 April 2007 Location: United Kingdom Status: Offline Points: 813 |
Hi Balistic I have posted the new earth shaker mid hi on your " LIGWA- intimidation" topic buy not a very good picture but give you a idea whats behind the grilles speak to you soon cheers
kevinmcdonough
defo all true Tony, have always respected the technical knowledge of the people on here and love how we can always get to the truth of any debate, especially with the electronics stuff which is an area i dont have a massive knowledge of. All i ment was this one fairly quickly went from heated technical discussion to being a little personal, which was perhaps unfair. k Edited by kevinmcdonough - 13 March 2012 at 12:16pm |
LIGWA
mykey-
Old Croc Joined: 03 March 2010 Location: ID/UK Status: Offline Points: 6114 |
isn't there a cash converters forum you can go hang out on? |
LIGWA
mykey you got so much talk and I have never heard one of you system
I have nothink more to say to you till I hear one of your system Further more I can't wait for LIGWA SYSTEM and your PAPER GRAPH SYSTEM to meet in Golden Palace Now! Dont try to Get some Soundmen to Help you out to sound good Just ME and YOU Lets see what really you know about sound system now! will not answer none of your threads till this event happens you got too much talk! but I still love you for that mate xx
Smiter
Registered User Joined: 21 August 2010 Location: UK Status: Offline Points: 1160 |
I did hear that what came out of those two scoops was pretty astonishing, regardless of numbers
audiomik
Old Croc Joined: 06 April 2010 Location: Bath, UK Status: Offline Points: 2962 |
Apology for not picking this up sooner but a comment by Ceharden posted a couple of days ago is I think well worth a follow-up:
"You need a true RMS Voltage and Current reading which also takes account of the phase to measure the actual power being dissipated by the driver and ignore reflected power due to the reactive nature of the load. I had the great idea to build one years ago..... Strangely enough it's another project that's never happened." Strange? Na - not an easy build by a long way! I've been running Power Transfer tests on 'Speakers on and off for a while now. http://forum.speakerplans.com/power-factors-for-speakers_topic52128_page1.html OK not a 'single box' test by any stretch of the imagination; but the results I get are very interesting - especially with the higher impedances of LF Drivers used for Bass below their XO frequency and VI phase angles of over 60º. Anyway we also need to know THD of the Current waveform to see how/when the 'Speaker is performing as a 'linear' load or not to calculate into the Power Factor figure. Definitely there will not be anywhere approaching the expected power getting near to voice-coils and larger diameter drivers perform worse on this from results so far. Reckon those Celestions were probably getting about 40% of available Amplifier output at best, plus this is frequency dependent. Would be interesting to see full test results for a Driver loaded into in one of the Cabs in this Thread - adding load to the cone can worsen the VI phase angles and Current distortion compared with 'free air' tests. Mik |
Warning! May contain Nuts
plus springs, washers, screws, etc, etc. |
LIGWA
Mate I think you need to come too and do so of you own testing and then you can relay the actual finding of the day and Get some Rise and peas with Jerk Chicken
audiomik
Vaguely possible only if suitable transport can be provided and the event is local to here for me to attend; however there are others fully capable of running the same tests.
thanks for the offer but....... Mik |
kevinmcdonough
shame i'm so far away, sounds like it could be an "interesting" day lol, we dont get many scoops up here north of the border so not something ive had a huge experience with. k |
LIGWA
don't worry we send you the the video experience..
I am looking forward to it... no venues up your end? We'll come and do a demo up there |
Muckerbarnes1
Old Croc Joined: 20 March 2010 Location: Stroud Status: Offline Points: 2654 |
Can you confirm the amp arangement?
Too much confusion. It is either a 2 channel (4r) running in bridge which will be 8R min load, or one case with 2 mono blocks ( a 2 ch amp then) with a min load of??? More info would be great. I'm sure Dave will know. We have all experienced more power o/p in watts than the 13A plug can provide. We have also debated correctly the reason and levels previously. I would however concurr that an 8R voice coil plugged into the mains would fry. Not in seconds either. More like milliseconds. If it did run for seconds I would debate the coil was to heavy and the mass would make the speaker way too ineficient. In which case an older amp and speaker would win. ( in simple terms) More info would be great. BTW forget the idea that PC's and graphs etc. are not accurate. Some of us can calculate without a PC. These engineers hand calcs will be accurate. This is what we strive. As an old engineer I still relate to; What has been will be again, what has been done will be done again; there is nothing new under the sun. This is largely true in engineering. How ironic for an engineer to quote this as it is in the 'Bible'. A great pat on the back for the effort to try and acheive more. More can be less, but I really hope in this case more is finally acheived.
Edited by Muckerbarnes1 - 15 March 2012 at 12:26am |
Billy Dawg.
