  New Posts New Posts RSS Feed - The Singing Canary Sub
snowflake View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote snowflake Quote  Post ReplyReply Direct Link To This Post Posted: 23 September 2016 at 12:25pm
if I were you I would make the box a bit bigger to account for higher Qes when the voice coil gets warm. If you make it deeper and tune a bit higher you might just fit a straight vent in. put more of a radius on the vent - 7cm radius flare on a 14diam tube. with vents that big you should be able to goup to 35m/s port velocity
