THE T.AMP TSA 2200 connecting XLR inputs to Jack |
Post Reply | Page 12> |
razorray
Registered User Joined: 06 December 2005 Location: London Status: Offline Points: 425 |
Posted: 05 June 2013 at 10:25pm |
THE T.AMP TSA 2200 connecting XLR inputs to Jack socket panel
I want to connect the 2 inputs from the amp to 2 1/4" Jack sockets on panel. -How should I go about doing this? -Should I be using the Male XLR or Female XLR -What about balanced or unbalanced The 2 x 1/4" Jack's will be on a 1U panel Or is this just another one of my crazy ideas.. http://www.ebay.co.uk/itm/Patch-Panel-19-1U-12Way-Rack-Mount-with-12-x-Jack-1-4-6-35mm-TRS-00165-/370814686798?pt=UK_Musical_Instruments_Rack_Cases_MJ&hash=item565647164e Sorry for so many newbie Qs. I have only been a member for 9 years.. |
djeddie
-Should I be using the Male XLR or Female XLR Male. Stereo, if you're using balanced, Mono if not. -What about balanced or unbalanced Does your pre-amp have a balanced out? Hope that answers some of it! |
razorray
Thanks Djeddie. So I guess the female XLR on the amp is for bridging. The pre-amp is quite old so I guess it is mono ''unbalanced'' Cheers Ray Thanks D |
all bass
female xlr is a parrallel out to link to another amp.
Earplug
Input to amp is the female, link out male, although it shouldn´t make much difference - until you try to link to another amp that only has the female in!
Blaize110
Young Croc Joined: 11 May 2010 Location: Gloucestershire Status: Offline Points: 673 |
Yup, what Earplug said. The pins point in the direction that the signal is going in. So the input to the amp is on the female sockets, therefore there should be a male plug coming from the patch panel.
(this only applies to audio, DMX is backwards :P)
Edited by Blaize110 - 06 June 2013 at 9:25am |
razorray
So I would have no make my own lead with male XLR going into the female XLR on the amp then connecting on the back of the jack patch panel then, So then use standard jack to jack cable from pre-amp to patch panel. |
mini-mad
yes.
razorray
mini-mad
i supose buying premade would cut the time down on making them.... to a point..
but yes the diagram is correct
razorray
Thanks mini-mad. Even if I bought premade XLR to Jack I still have to cut of the jack end and connect to the back of the patch panel. Cheers Ray |
mini-mad
