The Turbosound TMS-2A topic |
Page 123> |
| Author | |||||
4AC
Joined: 18 September 2010 Location: Netherlands Status: Offline Points: 271 |
Topic: The Turbosound TMS-2A topicPosted: 30 March 2012 at 6:31pm |
Hello,
A long post, so here is a nice video (even if you dislike the music it's a nice video, lol) Recently my brother and I purchases a pair of Turbosound TMS-2A speakers. The seller thought they were "some double 15" speakers or something". Luckily, we recognised the Turbo panel on the back. And, as you might have guessed, it was a real bargain. Altough it was quite a risk, because we had no idea if the inside was original, or even working. They looked like this when we bought them. After a quick removal of the panels on the back- and bottom, we discovered the following:
- The most important part -the 10" and phaseplug- is 100% original and working (1 and 2) - The 1" is original and working (1) - The 15" is a non-original RCF woofer, one with a completely destroyed cone and the other with a loose voicecoil. We presume that they both are bad recones, because the woofers are bloody old, but the cone and edge look really good for the age. Besides that, they are propably not the correct woofers for this cabinet, due to different T/S parameters (I GUESS, they might also be perfect as well). (1, 2 and 3) - One filter is perfect and original. The other filter had a rough time once, but has been replaced with something that seems OK. Not sure if its correctly repaired though? (1 and 2) - The previous owner made a 4P connection on the back, using a EP6 connector. (1) - About the previous user: he seems a clumsy, sloppy, messy, untidy, careless bungler. And thats something you see all over the cabinet. Firstly, he filled the whole cabinet with some kinda woodfiller or something like that. (1 and 2) And besides that, he molested this piece of British history by sticking a ugly black filt around the cabinet. We immediately started removing that. (1 and 2). Wich revealed the letters 'CVW' on the side. I have no idea what it stands for, I presume a sound rental company. Google doesn't know either. We want to bring this beauty back to a almost new condition. We have a few questions: 1) What is the difference between a TMS-2 and a TMS-2A? Active (bi-amped)? Or is it one of the thousand different versions (mkI, mkII, mkIII and so). 2) Is it correct that the Turbosound CD-101 is a rebadged Beyma CP300? 3) What are the original woofers for this cabinet? What are the parameters for this woofer? Are there any known replacements for this woofer? Does anyone know where I can find the original woofer nowadays? 4) Or is it worth the effort to recone the RCF's? The specs are promising: high efficiency and low power. Exactly what we want for this cabinet. We do not want a new, expensive, woofer with 92 dB sensitivity and 2000 watt programm! We just want the cabinet the sound at it's best again. 5) Is the repaired filter okay? 6) One cabinet was filled with acoustic foam in the 15" horn, the other one was empty. What is correct? 7) Considering the condition of the wood, would you recommend using a belt sander or a planing machine? 8) We would like to place a handle on each side of the cabinet. What would be the best place for mounting the handle? We thought behind the 1", above the horn of the 15"? 9) Is anyone else using the TMS-2A's? What do you think of them? How would it compare to, for instance, the TSA C115N (a regular 15/2 low XO-point beyma cabinet), the QSC HPR153i or the EAW KF650e? I know, totally different speakers, but how would they compare sound-wise? Thanks a lot in advance for your replies. Here is a link to a complete picture-album by the way: click Greeting, Teun Edited by 4AC - 30 March 2012 at 6:47pm |
Sound quality to the people
shagnasty
Joined: 30 July 2007 Location: Guildford, UK Status: Offline Points: 4464 |
Posted: 30 March 2012 at 8:23pm |
Speak to Pete Brosman for the Fane 15" you need, you can get a TMS-3 PD in there but you have to remove some the Turbo cd-101 is a beyma, but I don't know which one, again I use Pete for these...
Nice find!!!
They crossover @ 250 and if you want they sound amazing 3way active....
Risc_Terilia
Joined: 15 December 2007 Status: Offline Points: 520 |
Posted: 30 March 2012 at 9:25pm |
Result mate
SoundsUnlimited
Joined: 29 April 2007 Location: Surrey Status: Offline Points: 264 |
Posted: 30 March 2012 at 11:58pm |
In Answer to question 2
Yes the CD101 is a rebadged 16ohm Beyma cp300. The tms2s sound really nice and would be perfect over a double 18 or something similar so its worth getting them working properly although I would advise upgrading the compression driver to something newer like the B&C DE250 to bring them up to scratch with newer cabs Edited by SoundsUnlimited - 17 April 2012 at 11:56pm |
4AC
Posted: 31 March 2012 at 1:34pm |
Where can I find this Pete Brosman? Is he a SP member? Is it possible that there are different TMS-2's, with either PD or Fane woofers? I found the following item on ebay.de: click ![]() It is the LS-1506, surely a PD woofer. Turbosound's component map says I need a LS-1503, considering the serial number. Is that a Fane?
Thanks! I was hoping it to sound amazing as well 2-way, lol. We seriously do not want any more amplfiers, haha!
What do you mean?
Okay, thanks a lot. If the TMS-2A's really sound good, they will be over two or three Acoustic Line TSE copies a side (Ciare woofer).
Explain yourself, please. Is it because the diaphragm is getting tired or something? Other than that I do not know why the compression driver would need replacement. In general Beyma drivers sound pretty good. Or is a new B&C way better than this 'vintage' (lol) Beyma? Cheers everyone Edited by 4AC - 31 March 2012 at 1:39pm |
4AC
Posted: 31 March 2012 at 3:01pm |
Sanding...
https://picasaweb.google.com/lh/photo/Vw87m3kQcr7fVwNZPT7sy9MTjNZETYmyPJy0liipFm0?feat=directlink Edited by 4AC - 31 March 2012 at 3:05pm |
shagnasty
Posted: 31 March 2012 at 5:40pm |
The 1506 is PD, from the layout of your boxes (IE the HF wave guide) I am gussing you need a Fane, they can be changed but it does involve some wood work.
Sorry I didn't note you were in the Netherlands, Pete Brosman has a Company in London Call Crystal Pro Audio, he is really good at looking after older turbo stuff.
As for the HF upgrade, I wouldn't the Beyma sounds great and the B & C may not, the 10" on the Mid device of these boxes runs out to over 5KHz so the 1" isn't working in the area where they bark, for a 2 way box the B & C would help but for a TMS-x no need to bother...
SoundsUnlimited
Posted: 01 April 2012 at 1:13am |
The Cp300 are not a bad driver for there age I'm just saying you can get better now days , I changed my cp350s in my tse111 for some b&c de250s because the Beyma,s were not giving the sound I was after and its the best thing I did. read here for my post about it
http://forum.speakerplans.com/turbosound-compression-drivers_topic47105.html
Edited by SoundsUnlimited - 17 April 2012 at 11:57pm |
Tedski
Joined: 15 December 2006 Location: Netherlands Status: Offline Points: 355 |
Posted: 01 April 2012 at 2:47pm |
Gefeliciteerd.
We also have a pair of 2's (and 1s and 3s), they sound fantastic properly powered. We had a look to see if the PD 15 from our tms3's would fit in the 2s, but without serious modification they would not. We used to use Fane crescendo 15MB in them, they fit, but finding recones for them is hard. |
4AC
Posted: 03 April 2012 at 3:14pm |
Bedankt!
Awesome, what company are you? Always nice to hear someone is using the old Turbosound series in Holland. Do you have any idea what the original woofer is, for our TMS-2A's? What Fane? Would those Crescendo 15MB's work good in our TMS-2A's, do they have the correct parameters? Sound nice, any close to the original? If so, I probably go looking for a woofer that had similar parameters as the Crescendo. Cheers |
Timebomb
Joined: 11 October 2004 Location: Lancaster Status: Offline Points: 1709 |
Posted: 03 April 2012 at 4:56pm |
the fane sovereign 15 neo sims very nicely in this type of horn, i havent tested one yet though.
facebook.com/RebelbassSoundsystem
Risc_Terilia
Posted: 03 April 2012 at 6:04pm |
http://www.urbandictionary.com/define.php?term=result Edited by Risc_Terilia - 03 April 2012 at 6:05pm |
Page 123> |
Tweet
