  New Posts New Posts RSS Feed - TH-Mini - tapped horn  - by Danley Sound Labs
 Post Reply Post Reply Page  123 12>
TDA-Audio View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TDA-Audio Quote  Post ReplyReply Direct Link To This Post Topic: TH-Mini - tapped horn - by Danley Sound Labs
    Posted: 02 September 2008 at 5:44pm
Hi all
who made this cabinet ???
that say  ?
where take plan?
http://www.danleysoundlabs.com/tapped_horn.asp?MODEL=TH%20MINI
mykey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mykey Quote  Post ReplyReply Direct Link To This Post Posted: 03 September 2008 at 6:58am
thats weird, that looks like a tapped horn bin I did many, many years ago before Tom Danley named it the "Tapped Horn"
I'll do a quick sketch, Tre4u2nv may still have one, takes a 12''
img301/3361/12gu4.jpg
Edited by mykey - 03 September 2008 at 7:01am
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 03 September 2008 at 11:05am
I think it looks like this
Head of engineering
Bold Audio Inc
www.boldaudioinc.com
http://www.facebook.com/pages/Bold-Audio-Inc/323691856723
Jake_Fielder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jake_Fielder Quote  Post ReplyReply Direct Link To This Post Posted: 03 September 2008 at 3:16pm
Thats a pretty good guess i reckon,
Im abletronics, and so is my wife.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TDA-Audio Quote  Post ReplyReply Direct Link To This Post Posted: 03 September 2008 at 5:53pm
\\\\ looks like this\\\\\
to  Marjan...yes, approximately...
where take detailed plan???
what driver use???
Deadbeat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Deadbeat Quote  Post ReplyReply Direct Link To This Post Posted: 03 September 2008 at 6:15pm
Close, but no cigar, Mykey. I would reckon that would be a bass reflex meself...tapped horns function quite a bit differently I think. Ah, but many years ago there was the Jensen transflex and JBL air coupler and EV T18, though, I think? But then again none were exactly a tapped horn by any means...
TDA, as with all (excluding the Labsub) of Tom's designs, he does not give you any plans (unless you are as unchivalrous enough to open a box and post a plan, unlike most designers he is an active force on the internet), but instead dispenses lots of easy to find advice on designing such horns, indeed you can design one quick in hornresp, and I believe djk has designed a bin of similar proportions taking a 12.
Good day.
Away on extended leave.
Disco Stu View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Disco Stu Quote  Post ReplyReply Direct Link To This Post Posted: 03 September 2008 at 6:45pm
Yep I think Tom doesnt try and shroud his products in secrecy like some. He knows that if people want to find out how a box works they can just open it and see. That doesnt mean they can copy it and get a good sound though. He knows this which is why he appears honest and open about the theory.
Stu
All you need to know is:
My acts:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Deadbeat Quote  Post ReplyReply Direct Link To This Post Posted: 04 September 2008 at 9:52am
An interesting TH-mini alternative plan by Patrick Bateman:
http://www.diyaudio.com/forums/showthread.php?s=&postid=1601818#post1601818
Post Options Post Options   Thanks (0) Thanks(0)   Quote TDA-Audio Quote  Post ReplyReply Direct Link To This Post Posted: 04 September 2008 at 10:11am
\\\\\An interesting TH-mini alternative plan by Patrick Bateman:
not plan...
only test sub,s ...
Post Options Post Options   Thanks (0) Thanks(0)   Quote TDA-Audio Quote  Post ReplyReply Direct Link To This Post Posted: 04 September 2008 at 10:13am
\\\\\\\\\\\\\\\\\\Danley Sound Labs TH-mini - List $1295 ($1425 for flyable version)
I was quite impressed with the amount of low-end that came out of these boxes. They aren't much bigger than most computer towers and yet they would fill the room with a nice pleasing low-end. Their response does drop off down really low but they should work incredibly well for anyone looking for super compact but great sounding subs. As Ivan mentioned, these are geared for super portable systems or space constrained installs.\\\\\\\\\\\\\
Post Options Post Options   Thanks (0) Thanks(0)   Quote Deadbeat Quote  Post ReplyReply Direct Link To This Post Posted: 04 September 2008 at 11:23am
not plan...
only test sub,s ...
That's all you will be getting off the internet, I'm afraid, that, and djk's sub. There are no plans, (even if there were, I wouldn't link to them as it directly contradicts the rules of the forum asking for current production models). Asking for Danley sound labs plans is akin to asking for Funktion one plans...only the man tells you how to design and make boxes operating under similar concepts.
You have to make your own plans from the hornresp inputs.
I believe djk has a rough diagram of his TH-mini alternative.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TDA-Audio Quote  Post ReplyReply Direct Link To This Post Posted: 11 June 2009 at 6:15pm
my version Tapped Horn
still
based plan Staip
http://speakerplans.com/forum/staiper-design-for-learning-hornresp_topic24297.html
I calculated... wide resize...
This page was generated in 0.140 seconds.
speakerplans@redhotmail.net
