TH-Mini - tapped horn - by Danley Sound Labs |
Page <1234 12> |
| Author | ||
jethrocker
Joined: 07 June 2006 Location: Chiapas, Mexico Status: Offline Points: 1942 |
Posted: 12 June 2009 at 5:07am |
Interesting TDA... how does it sound..any measurements or even just simmed response?
edit: OP name confusion. Edited by jethrocker - 12 June 2009 at 10:19pm |
S.A.L.S.A
Joined: 15 June 2008 Location: Aruba DC Status: Offline Points: 21 |
Posted: 12 June 2009 at 3:09pm |
How are the results in comb. with the NEXO LS1200 sub??
Does it goes louder and deeper??
Nice bin!
Dave
Get to the Point with L'acoustics Dv-Dosc!
bitzo
Joined: 20 November 2007 Location: Italy Status: Offline Points: 977 |
Posted: 12 June 2009 at 3:22pm |
I think he doesn't use this bin in combo, probably he has stacked on a nexo to facing the external dimension. Just IMHO
Ibex
Posted: 13 June 2009 at 10:20am |
Very nice!!!
TDA, which driver do you use in your cab? How does it sound? Did you make a comparison to the original th mini? Does your design play deeper or loeder than the one from tom? Measurements would be very interesting! |
TDA-Audio
Joined: 11 February 2005 Location: Russian Federation Status: Offline Points: 289 |
Posted: 15 June 2009 at 9:32pm |
inside 18" version
jethrocker
Posted: 16 June 2009 at 6:59am |
Very nice ... but we still want answers :)
Ibex
Posted: 16 June 2009 at 7:11am |
Seems that TDA's real intention is to give us some philosophic thoughts
Although i'm as well very strained to get some auditory impressions from TDA corresponding on the 12" and the 18" modified tapped constructions. Edited by Ibex - 16 June 2009 at 7:50am |
Father-Francis
Joined: 24 October 2007 Location: Kenya ,Denmark Status: Offline Points: 1959 |
Posted: 16 June 2009 at 8:21am |
TDA write in Russian we will translate , no worries I´l speak for some of us we getting more outernational ![]() |
Optimism means expecting the best, but confidence means knowing how you will handle the worst. Never make a move if you are merely optimistic Music is the strongest form of magic.(+45 31879997)
TDA-Audio
Posted: 16 June 2009 at 3:39pm |
yes . I Max Peshkov has reported on forum
18" version - full still Staip
12" version - recalculated ....
i used
I am a test driver"s - p-audio p-120\130Lf
B&c 12nw100
Ciare 12.00sw Beyma 12Lx60 P-Audio SD-12EL
and 18"
18lw1400
18tbx100
18" cabs - good pressure, but big weight.. (for 18tbx100).
18lw1400 - no good work..
12"cab - ciare - very big pressure!!
12"nw100 - good, but much loses ciare...
12LX60 - Very Good. SD-12EL - good.
12 versions -preference...small size! and good pressure for their own size Tapped Horn and Scoop"s - different cabs ... Edited by TDA-Audio - 17 November 2009 at 8:36pm |
TDA-Audio
Posted: 16 June 2009 at 3:50pm |
LS1200 vs TH 12"
12" 48hz -6 db.
ls-1200 32hz -6db
pressure th-12" vs LS1200 (street)
for 1 m - ls1200 more pressure
but 15-20m - TH-12" vs Ls1200 - approximately equally pressure.. |
Ibex
Posted: 16 June 2009 at 9:30pm |
First of all: TDA, thanks for answering!
I think the 12NW100 has the same parameters as the 12PS100 but with neodym instead of ferrite? Isn't the response of the 12" version loaded with the Ciare a little bit peaky in comparison to the B&C? Did you annoy the minimum at 80Hz when you were listening to music and/or made your comparison/measurements? That is, what the simulation says: ![]() black = B&C 12PS100 grey = Ciare 12.00SW |
Ibex
Posted: 17 June 2009 at 6:05pm |
TDA, i'm not able to reconstruct what you said, my results are nearly congruent with both drivers... ![]() ![]() ![]() black = 18Sound 18LW1400 grey = B&C 18TBX100 |
Page <1234 12> |
Tweet
