ThomannĀ“s cheap 18" driver in G-sub? |
Post Reply | Page <1234 8> |
djyves
Young Croc Joined: 06 April 2009 Location: the Netherlands Status: Offline Points: 564 |
I got to find a very cheap 18'' replacement for my school.
The have ohm le-18 horn loudspeakers that need new drivers. Will these work, or rip apart
Walle_W
Registered User Joined: 24 August 2010 Location: Sweden Status: Offline Points: 79 |
Thank you technofreak for taking your time and effort.
djyves
doesn't anyone know if they will survive in horns? |
Walle_W
I now have two G-subs with theese drivers.. I feed them with one TA-2400 1200wrms per box.
But will they survive say a Proline 3000 @ 1500wrms per box? Or should i stay with the smaller TA-2400 or should i go even bigger as the T.amp D3400 @ 1800wrms per box? I know the D3400 is not a recomended amp. But lets keep the question simple! How big a amp should i have to get as much as i can out of my budget G-subs without burning them up the first night!
The Builder
Old Croc Joined: 03 January 2010 Status: Offline Points: 3107 |
One blow up and your not budget anymore.
Keep the 2400.
It just is.
Walle_W
So iĀ“m almost finished with my Gsubs. Only grill left..
I sold all Tapco stuff and bought a pair of The Box ACHAT 215 instead. Also got another 2400 instead of the 1400 i used to have for tops. But the most important thing is that iĀ“m halfway with my second pair of GĀ“s Maybe i will try some XBĀ“s this time. Not desided yet.. Thomann x4 = 488euro Fane XB x4 = 888euro |
Pieter
New Member Joined: 16 November 2010 Location: Genk - Flanders Status: Offline Points: 4 |
Hi,
I'm reading this thread with big interest.
I've made a driver-profile in WinISDpro. Only unknown value was the Sd and because it's quite similar to the Fane Colossus 18XB, i've took the Sd of that driver (being 1120 cm^Ā²)
If i want to simulate 1 driver in a reflex loaded box of 160L tuned to 35Hz (with a lowpass 4th order Butterworth at 100hz, highpass 4th order Butterworth at 30Hz and a parametric at 35Hz, Q=2 and with a gain of 6dB)
I'm using two quadrangular ports of 14 by 14 cm, because i want to make it with 4 triangular ports of 14 by 14 + diagonal
Transfer function magnitude: http://www.mijnalbum.nl/GroteFoto-QYTDC8SH.jpg
Cone excursion: http://www.mijnalbum.nl/GroteFoto-U4BT6UEG.jpg
Am I doing something wrong or am I just expecting to much from this driver?
Edit: I'm inserting 400W of amplifier power. Edited by Pieter - 16 November 2010 at 10:30am |
THECANDLEMAN
Young Croc Joined: 08 December 2008 Location: CentralScotland Status: Offline Points: 1144 |
Hey man, great progress !
interested to know what type of gigs you do or hope to ?
and what size / where ?
Im building a similar set up with a 2nd set of double subs however im using a 2x15 rather than 2x18 but with very similar tops 2x15 + 2"
Motion Systems - Void Airmotion, Airten & Stasys 218 With Powersoft DSP
Flano
Registered User Joined: 29 April 2006 Location: Ireland Status: Offline Points: 216 |
How do you find the achat boxes?They look quite nice...
DMorison
Old Croc Joined: 14 March 2007 Location: Aberdeen Status: Offline Points: 1647 |
400w plus the 6dB of boost = 1600W as far as the excursion is concerned, which is why you've ended up over 10mm.
As noted further up the thread, the calculated Xmax could be considered to be just over 8 mm, so you won't have to reduce your boost much to stay within this (probably to 1000-1200W, at a guess). Or, reduce the box size and increase tuning frequency a bit to bring it under control.
Hope this helps,
David
Pieter
Hi, Been a while since I've been here, I do apologise for that
Well I've dropped the 6dB boost and indeed the speaker was fine.
Thanks for the input, it helped.
Pieter
Walle_W
Outing the rig for the first time on saturday. I have not seen the place but they say it can hold 200p. I will be doing it for free this time since it's the first time and i can't give any guaranties that my rig lasts all night :P But i'm hoping to be able to do "normal" parties and disco's (club it's called today i think? :S) up to 300p? And small Dubstep events up to 100p? In GƤvle, Sweden Edited by Walle_W - 17 December 2010 at 3:24am |
