Thomann´s cheap 18" driver in G-sub? |
Page 123 7> |
Walle_W
Joined: 24 August 2010 Location: Sweden Status: Offline Points: 65 |
Topic: Thomann´s cheap 18" driver in G-sub?Posted: 24 August 2010 at 12:36am |
Hi there.
I have came across two "the box speaker 18-500/8-A" (Thomann.de) Will they work in a G-sub? This is the parameters that followed with the speaker. Fms: 40,1Hz Qms: 7,61 Qes: 0,45 Qts: 0,43 Res: 103,3ohm Rms: 6,1kg/s Cms: 0,09mm/N Mms: 184,9gr Nref: 2,86% Bl: 23,8N/A SPL: 96,6dB Vas: 208,3l Re: 5,5ohm Rp: 84,1ohm Lp: 49,0mH Cp: 566,8microF Le: 1,3mH The driver costs 122euro. Should i just sell them and get the PD186 (255euro) or get to more of these and build two cabs? I´m not out for the absolutly highest performing subs. Just for small events and mainly dancechart music. Got two tapco 6918 (single 18 reflex) and they are just a little to small for me. Sorry for my spelling
It´s been 10years since i opened a english school book.. |
Walle_W
Posted: 02 September 2010 at 2:35pm |
tought i would give it a try.
![]() It has higher sensitivity, plays deeper and just overall sounds better than my Tapco´s.. I could (only from comparing with my Tapco´s) clearly recomend these drivers as a budget alternative. Is used Tapcos in Edited by Walle_W - 05 September 2010 at 10:51pm |
Tekasis
Posted: 02 September 2010 at 2:47pm |
Don't blame you mate! Sometimes you need to just try things out yourself. But be careful though, as sometimes it can become a waste of money! Glad for the update!
**Heavy Weight-Line**
A home without books is like a body with no soul. |
Walle_W
Posted: 02 September 2010 at 4:24pm |
Thank you.
I got these two drivers cheap so had to try something with them. I built two boxes and tought that if these did not work i´d buy PD or Fane to put in. But now it looks like i will be ordering two more of these ![]() Now it´s only the fun part left with fixing handles, grill and paint. ![]() |
Stray-Sounds
Joined: 13 March 2008 Location: Wales Status: Offline Points: 2319 |
Posted: 04 September 2010 at 2:27am |
cant you get fane xbs for the same price though?
Walle_W
Posted: 04 September 2010 at 11:51pm |
Is a bit of difference actually. PD186 255euro FaneXB 222euro Thomann 122euro And since a already got two so is it only 244euro to spend, changing to xb´s would set me back 888euro. |
Stray-Sounds
Posted: 05 September 2010 at 9:45am |
I see. must be different over there. my mate haggled 1 shop down to £108 each brand new
tweeter box
Joined: 21 October 2007 Location: United Kingdom Status: Offline Points: 6776 |
Posted: 05 September 2010 at 11:10am |
any idea what the xmax on the driver is?
Walle_W
Posted: 05 September 2010 at 10:39pm |
No. All that i got with them is in the first post. But i´ll email Thomman and ask.
technofreak
Joined: 24 August 2008 Location: Estonia Status: Offline Points: 74 |
Posted: 06 September 2010 at 9:20am |
Hi, The datasheet of the driver is here. The X-max is 5,4 mm [(Hc-Hg)/2], or 8,15 mm if you use (Hc-Hg)/2+Hg/4. (Hg - height of magnetic gap; Hc - height of voice coil). |
soundguymatt
Posted: 06 September 2010 at 12:46pm |
my question would be what's better? this or the fane XB?
technofreak
Posted: 06 September 2010 at 3:34pm |
They seem to be quite similar. In a 200 L box tuned to 35 Hz both have average maximum output of about 124 dB, but Fane is ultimately a bit louder below 50 Hz, whereas Thomann's is a bit louder above 60 Hz and has a bit smoother group delay curve. Both should be within their X-max limit at their RMS power - Fane's calculated X-max [(Hc-Hg)/2] is 6,5 mm, in spec sheet it's 7,5 - (Hc-Hg)/2+Hg/10; using this formula on Thomann's offering, we get 6,5 mm. If the Thomann's driver has good and consistent build quality and parameters, it should be one of the best budget 18" drivers. Red - Thomann 18" Orange - Fane XB |
Page 123 7> |
Tweet
